M
michael percy
I have an extension which I need to wire up lighting inside and outside.
I have 1 wall light and two external halogen lights and I want all three
switched from the same place but on its own switch.(simple enough)!!
I have run a permanent live and neutral from the upstairs lighting circuit
to the switch box and from there I have run 1 cable to each light fitting, I
intend to put the permanent live to the first common on the switch and then
loop to the next two commons on the switches, then I intend to run a live
from the opposite side of the swithches to each light fitting and connect
all three neutrals together with the permanent neutral.
2 electicians have told me this is correct and 1 electrician has said its
not right.
so, who is right ??
mike
not right.
so, who is right ??
mike
