Hi, recently the cabinet that I house my ps3 in has been getting pretty hot so I thought i would see if theres a way i can install a fan at the rear to extract the warm air away while drawing in fresh.
What I had in mind was buying a 20cm computer case fan and then wiring it to one of the ps3's USB ports, so that it only comes on when the ps3 is switched on.
Only problem is most of those fans are rated at 12V and USB only provides 5V. Now my question to you, the electronics community, is there a way I could use 2 usb cables to provide 10V to the fan. I would need a way of ensuring that no voltage is back fed into the ps3, i was thinking a few diodes or a bridge rectifier perhaps would do this.
I will only be using the +5V and ground wire on each of the USB cables for this.
Many thanks in advance, Iain
