SMP's
Hello Eric.k.
Your transformer looks like a switch mode power supply, this is an electronic type transformer, not to be confused with a linear transformer of iron lamination and copper windings, your link gives two data profiles, each has five models on it from what i can make out, which model number is yours ?. secondly as it a switch mode power supply it will give you 12 volts DC if you have that model, there should be either two leads for the mains, one blue and one brown ( neutral / live ) or a pcb socket that takes a plug, usually to pins, sometimes more, depending on its manufacturers use, there may be variations on those colors, the input mains voltage is any where between 85 and 264 AC volts in.
The supply is suppose to be double insulated, meaning there is probably no earth or ground wire to connect up, its case must comply with installation standards in your country for safe use, i would advise you strongly not to connect it up until you have an enclosure for it.
The model number would be more helpful of the unit you have, and its intended use, as you give no indication. Dave.
