Wiring a reversible 24v dc motor
Discussion in 'Electronic Design' started by nffcspw, Aug 2, 2006.
  1. nffcspw
    nffcspw Guest
    Hi all,
    I've thrown myself in at the deep end with a university project and
    have hit a wall with my lack of experience in electronics.
    I have a 24v dc reversible motor that I'm hoping to drive off two
    seperate outputs from a Zelio smart relay. I can get the motor to turn
    individually in both directions if I wire the Zelio outputs up one at a
    time(ie wire one up and leave one output disconnected).
    However, if I wire them both up to the unit, it "reboots" itself and
    doesn't drive the motor at all.
    I assume this is because I have the two sets of wires connected
    directly to the motor in order the "reverse" the polarity when needed,
    but I can't think of what to do to solve my problem.
    I originally thought of having diodes?? inline with the wire befor I
    connect them to the motor, but I don't know if this is correct or would
    work.
    I'd appreciate any help any of you could give. many thanks
    Steve
  2. Dunno what a zelio is, got a URL?
    martin
  3. colin
    colin Guest
    Usualy you would need to wire one end of the motor to one relay and the
    other end to the other relay.
    this is assuming the relays are spco type with top/bottom contacts connected
    to +24v/0v
    Colin =^.^=
  4. nffcspw
    nffcspw Guest
  5. Don't know what kind of animal Zelio is but ANY DPDT(Double Pole Double
    Throw) relay should do.
    The motor connected to the common terminals a and b
    Power connected 'positive' to NCa and NOb (Normally Closed and Normally
    Open)
    Negative power connected to NCb and NOa.
    Activating the relay reverses polarity of supply to motor.
    HTH
    Stanislaw
    Slack user from Ulladulla.
