Wiring a microphone (I'm a noob)
Discussion in 'General Electronics Discussion' started by mae, Aug 2, 2011.
  1. mae
    mae
    Aug 2, 2011
    Hey there,
    So I bought a 2.5mm male to 3.5mm female adapter to wire into my ContourHD sports camera so I could replace the crappy microphone in it and attach another. But when I received it and stripped the adapter casing off the wire, I found that there is 3 wires in the casing. The camera has just negative and positive wires for the microphone.
    Is there a way to still wire these two together? If so which colours would go where? Dark blue to black, red to positive and the copper wire to where?
    Cheers
    (sorry if this is in the wrong section)
    [​IMG]
    [​IMG]
  2. TBennettcc
    TBennettcc
    292
    Dec 4, 2010
    You say you bought a 2.5mm male to 3.5mm female adapter. So where is the 2.5mm male part you cut off? Can you 'ring out' the wires to the different parts (tip/ring/sleeve) on the 2.5mm part? Maybe we can go from there...
