Wiring a 9 Pin D connector for standalone Logitech sub-W
Discussion in 'General Electronics Discussion' started by Chris S, Jan 20, 2018.
  1. Chris S
    Chris S
    8
    Jan 20, 2018
    I have a Logitech X-230 subwoofer with 2 satellite speakers, one of which has a power switch and volume control. These satellite speakers attach to the passive subwoofer via a 9'pin D connector.
    What i am trying to achieve is to connect the subwoofer to my mini HiFi system's single Subwoofer RCA.
    I assume that this can be done, however I haven't dabbled in circuits for over 30 years so I need some help from this forum.
    I have uploaded a file which I found online showing the 9 D pin wiring diagram and I would really appreciate it if you Wizzards out there could advise me how to wire this in order to bypass the satellite speakers and connect the RCA cable directly to the subwoofer.
    Many thanks in advance for your advice and suggestions.
  2. Harald Kapp
    11,313
    2,593
    This should answer your questions.
    Forget the potentiometers, directly connect pins 2 and 9 of the S-SUB to the stereo jack.
    Add a switch between 6 and 8 or simply short-circuit these pins for permanent on.
  3. Chris S
    Chris S
    8
    Jan 20, 2018
    Thank you for your quick reply Harald. I tried this but it didn't work. Are there any other pins that should be connected together?
    Cheers,
    Chris.
  4. Chris S
    Chris S
    8
    Jan 20, 2018
    Oddly though, I connected 6&7 together and pin 2&4 to the RCA and it works. Confused!
  5. BobK
    7,682
    1,688
    2 and 5 would seem to be the correct input pins for the RCA connector, inner to 2, outer to 5.
  6. Chris S
    Chris S
    8
    Jan 20, 2018
    Thank you Bob. I will try this tomorrow.
  7. Bobbypfreely
    Bobbypfreely
    Apr 17, 2018
    Hi, did this work?
  8. Chris S
    Chris S
    8
    Jan 20, 2018
    Yes it did. I intended to post this ages ago, but I got sidetracked with work, etc, then I just forgot!
  9. Bobbypfreely
    Bobbypfreely
    Apr 17, 2018
    Which config did you go with
  10. manhy16
    manhy16
    Feb 11, 2019
    Hey Chris im about to do the same thing, could you give some info on what you did?
  11. djjapa
    djjapa
    May 3, 2021
    hello i'm new around here excuse me the english from google translator I would like a help from you with the correct pinout (9 pins) of the logitech x230 male connector thanks in advance thanks
  12. Harald Kapp
    11,313
    2,593
    Read post #1?
