john
I build the device with 64 constant current sources . The device has
following specifications
1. 0 to 1mA current bipolar.
2. compliance voltage +/-15 volts
3. Frequency 100 to 1 khertz
I isolated the current sources with tranformers of follwing specs.
primary inductance : 5H
Secondary inductance : 5H
Turn ratio: 1 : 1
So, the load impedance connected across the secondary reflects back to
primary. The device is working good. But now, according to new needs,
I have to make it wireless. The things that are confusing me are
following
1. What do I exactly need to make the system wireless, Do I need a air
core transformer?
2. If all current sources generating the output at same frequncy then
how the receiving end will properly get tune d for it. For example if
current source #1 generates a sine wave of 200hz and another current
source is generating triangular wave of 500Hz does it then isn't there
a chance that the receiving end might catch wrong signals.
Please advice!
John
Turn ratio: 1 : 1
following
core transformer?
Please advice!
John
