Hi everyone,
As you can see im a new member in this forume, and the reason for joing you guys is because of My final degree project.
This project is designing and making a version of serial adapter similar to the one in link below:
http://www.synapse-wireless.com/index.php?mainID=12&subID=11&type=product&prodID=11
However, the version im desiging should be compatible with both RF200 and RF300, and it also use a 4line recieve and transmitter RS232.
Im familiar with the circuit and RF modules as well as RS232.
This version of serial adapter is operating by using a 3.2 v battery and a solar pannel that is reacharging the battery.
As you know this projects takes one semester for me and i will ask my questions regard to this project in this post.(You can find an initial desing of the system in attachement)
My industry partner asked me for a 4 line drivers, 4 line recievers RS232 that operates at 3.2 v.However, i had search on internet and i could not find any version of this device. My idea is using two max3223 instead. Doese any one else has any idea???
Also, as i already mentioned the system has to work with both RF MODULES. But it is not nessecury to use any terminals. RF200 and RF300 has just 3 analouge output and i want to use these output for temp sensor, battery voltage sensor and humedity of the enviroment since the system has be placed in a proof box to be used in outdoor.
What do you think about these sensor? Should i use a simple sensor by using diode and LED or there is other ideas?
I will ask any question regard to this project at the end of this post!
Once again thank you for answering my questions
