Wireless reed switch
Discussion in 'General Electronics Discussion' started by arjfca, Sep 12, 2013.
  1. arjfca
    arjfca
    Sep 12, 2013
    Hello
    First post on the forum
    I'm looking for an idea on witch wireless device I could use to read the opening of a door. My actual installation use a reed switch with a magnet and it is link using a wire. The switch is normally open and when the door is open, it goes to close position.
    The distance is less the a meter ( 3 feet)
    I'm looking for an inexpensive and easy to use solution
    Any idea?
    Martin
    Montreal Canada
  2. Harald Kapp
    11,961
    2,798
    Buy a remote doorbell (using radio technology). Connect the reed switch in parallel to the sender's button. Voilá.
  3. arjfca
    arjfca
    Sep 12, 2013
    Hello Haralk
    I know I could do that, but the goal fun is to create it.
    Martin :)
  4. Harald Kapp
    11,961
    2,798
    Make an LED light up when the door is open. Use a PC and a webcam to detect the light from the LED.
  5. BobK
    7,682
    1,688
    No, that is too simple Harald.
    The reed switch operates a solenoid.
    The solenoid releases a 1 inch ball bearing that runs down a spiral track.
    It Then falls into a cup at the end of a 1 m long lever
    The lever, through gearing runs a fan.
    The fan provides wind to move a model sailboat across of trough filled with water.
    When the sailboat reaches the other side, the trough is unbalanced and tips, so the water spills out.
    The water runs through a small hyrdro-electric generator.
    The generator powers an animatronic monkey, who waves a flag, signalling that the door has opened.
  6. Harald Kapp
    11,961
    2,798
    Greetings from Rube-Goldberg.
    You're absolutely right. How could I post such a primitive solution ?;)
  7. Harald Kapp
    11,961
    2,798
    @arjfca:
    Pardon our jokes, we too need to relax from time to time.
    Honestly: what is wrong with the simple solution? It's inexpensive and easy, just what you had asked for.
    If you want to "create" something by yourself, what is your background? Do you have any experience in electronics? Do you have any experience in hf-design?
    Look for an RF remote control kit at the electronics shop of your choice. A kit will make it much easier for you to get started.
