Wireless microphone crystals
Discussion in 'Electronic Design' started by Spehro Pefhany, Jan 3, 2014.
  1. Hi,
    I ended up with a VERY old stack of 50-100 paper envelopes, each
    containing at least one crystal HC-49 full size. Some are new, some
    pulls.
    There are alien markings like 77-TX and T82B-TX as well as frequency
    numbers such as 154.60, 171.025, etc. The frequency numbers are
    related to the stamped crystal frequencies by a factor such as:
    fcrystal = (1/2) * (frequency - 21.4MHz)
    Are these things of any use to anyone here? If so, they're yours for
    the cost of postage (should be less than $15 to anywhere in US or
    Canada). Otherwise, they'll go out in the trash
    I imagine modern mics are all synthesized from a single crystal
    source.
    Best regards,
    --sp
    Best regards,
    Spehro Pefhany
  2. Phil Allison
    Phil Allison Guest
    "Spehro Pefhany"
    ** Put them on Ebay.
    Bet someone bids a couple of bucks each for them.
    BTW:
    Transmit crystals (TX) used in most radio mics are a special cut that allows
    them to be easily "pulled" by up to 0.05% to create FM.
    .... Phil
