wireless elevator
Discussion in 'General Electronics Discussion' started by muhammad tehmaas hasan, Jul 2, 2011.
  1. muhammad tehmaas hasan
    Jul 2, 2011
    hello friends
    i want to make my course project i.e wireless elevator. the core components are.
    - 12 volt dc gear motor. with high torque
    - transmitter and receiver of a four way remote control car.
    FUNCTION OF THE ELEVATOR:-
    The function of the elevator is just to move up and down. i want to control by using the remote of the wireless car.
    COMPONENTS THAT COULD BE USED TO MAKE ITS CIRCUIT:-
    I want to use a h-bridge l298.
    or a simple relay circuit will do the job.(attached in this mail).
    now i want to design a circuit to move the elevator up and down using above mentioned components.
    here use of any type of micro controller is not good because i have not used and studied them yet. so kindly guide me how can i make this project
    in a simple way.
    if any more simpler way could be implemented over here would be lovely.
    all the necessary files are attached have a comprehensive look and kindly explain me in detail that how can i make this project. if any particular component you mention in your explanation kindly tell the model number and other required details.
  2. KMoffett
    KMoffett
    716
    71
    Jan 21, 2009
    1. How much current does the gear motor draw...the maximum current starting-up under load or stalled?
    2. Do you have a schematic of the wireless receiver?
    I've made short-range (~3 meters) wireless switches with the little ZipZap car remotes. The attached is how I changed the 1.5v output of the small receiver PCB in the car to a 5V logic level. With two of the outputs (B/F motor or L/R steering) you could drive an H-bridge to control the motor for up-down-stop.
    Ken
  3. muhammad tehmaas hasan
    Jul 2, 2011
    wireless elevator.
    yes you are right i have to check that how much current the motor is drawing for my respective load.
    i will soon give you exact detail
    tehmaas
