Wireless Battery for Electric Drill failure Ryobi
V
Vlad
I purchased this unit less then a year ago that comes with two set of
batteries.
One of the batteries failed (short circuit) .I open the unit that
consists of 10 Panasonic batteries and all of them are in short
circuit.
I wonder what makes ALL of them to short circuit.
Vlad
T
Travis Jordan
batteries.
circuit.
Although rare in a 1 year old battery, this is usually a sign of
dendrites... whiskers of nickel that grow within the cell as the cell
ages. The dendrites can grow long enough to make a short circuit between
the poles of the cell.
M
mike
batteries.
circuit.
Vlad
Does seem unlikely. Are you sure they're all shorted and not merely at
zero volts?
Problem is user misuse plus dumb fast charger.
You're drilling a hole. The drill starts to slow down. You finish the
hole. Maybe you're in a hurry and drill the last two holes too.
Result, one battery reversed. Next time the weakened cell reverses
sooner, but the others are still good and you keep drilling until it
slows down markedly. Result, one cell seriously damaged and
damage started on the next one. Eventually, one shorts. The charger is
dumb and charges the crap out of the others trying to get the n-1 pack
up to n volts. Cells overheat and vent.
Viscous cycle destroys the pack.
It is unusual for ALL to go shorted at the same time.
It is not unusual for overheated cells to self-discharge and all end up
at zero volts rather quickly.
The premeptive solution is to make sure the battery is fully charged
before you start and stop before it's fully discharged. This is
difficult. If you sense any sudden weakening in torque, stop
immediately and recharge the pack. If you start drilling with a battery
that's been fully charged then set on the self for two weeks, you're
asking for trouble.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
V
Vlad
zero volts?
asking for trouble.
mike
Mike
I didn't realized they were so difficult to please . Worse then my
mother in law.
Vlad
