Wire size question
Discussion in 'Electronic Equipment' started by [email protected], Dec 6, 2007.
  1. Guest
    If I have a 10 hp, 230 vac, 3ph motor with a current draw of 24 amps.
    I would fuse it with a 30 amp time delay.
    OK now my question. Do I wire it with the capability of handling 24
    amps or 30 amps?
    Thanks for the help.
  2. Jamie
    Jamie Guest
    you calculate 25% over the Max expected current.
    so,
    24 * 1.25 = 30 amps
    Is the minimum to start with, then you have length of
    wire to consider.
  3. PeterD
    PeterD Guest
    How long is the wire?
  4. Guest
    It's nothing, a few feet.
    Thanks for the help guys.
