When I go to start Explorer I type Windows+E. There is no shortcut to
right-click.
Tim
Because there doesn't seem to be an easy way to modify the existing
Windows Logo key + E shortcut you could use the Windows Logo key and
another key to create your own shortcut to start explorer in a folder
of your choice. Windows doesn't provide the capability to create a
shortcut using the Windows logo key. But a free ware program called
WinKey does. See
http://www.softpedia.com/get/System/OS-Enhancements/WinKey.shtml
to obtain a copy of Winkey.
To create a shortcut start Winkey and click on "Add". In the
"Shortcut Properties" dialog click on the arrow on the right side of
the "Shortcut Key" drop down list box. You will see a list of key
stroke combination you can. For this example I suggest using Windows
Key + X. Next in the "Command" text box enter C:\Windows
\explorer.exe Next in the "Parameters" text box enter /e,root,C:\
This is the same sequence Sphero recommended. Finally click on "OK"
Here is a list of shortcuts "Windows uses and can not be used when
creating user defined shortcuts.
• Windows Logo (Display or hide the Start menu)
• Windows Logo+BREAK (Display the System Properties dialog box)
• Windows Logo+D (Display the desktop)
• Windows Logo+M (Minimize all of the windows)
• Windows Logo+SHIFT+M (Restore the minimized windows)
• Windows Logo+E (Open My Computer)
• Windows Logo+F (Search for a file or a folder)
• CTRL+Windows Logo+F (Search for computers)
• Windows Logo+F1 (Display Windows Help)
• Windows Logo+ L (Lock the keyboard)
• Windows Logo+R (Open the Run dialog box)
• Windows Logo+U (Open Utility Manager)
Howard
