Winding a mobius coil?
Discussion in 'Electronic Design' started by Mark Roberts, Sep 16, 2005.
  1. Mark Roberts
    Mark Roberts Guest
    I need to wind mobius coils from 0.8mm copper enamel wire. Finished
    diameter, or length (depending on winding configuration) is around
    45mm. Maximum thickness is 15mm. They can be either on a core or not.
    This is for an experiment and I need to make a few dozen. So I am
    looking for the least manually intensive technique, one that does not
    involve individually knoting each turn.
    Something like making a multi-turn loop, twisting it in half and
    folding over repeatedly. But I am not really sure how this would work,
    or the results compare with the more time-consuming methods.
    Does anyone know?
    Mark Roberts
  2. ryan weihl
    ryan weihl Guest
    google is your source "mobius coil"
  3. Pooh Bear
    Pooh Bear Guest
  4. Pooh Bear
    Pooh Bear Guest
    Google finds several sources
    http://www.littlemountainsmudge.com/mobiuscontinuosknot.htm
    http://www.ryanmcginty.com/orgone/mctutorial.htm
    Are you researching orgone energy ?
    " I add activated carbon granules to the resin while still in the liquid
    state. Since humans are carbon based, the frequency signature of carbon is
    enhanced and amplified with positive OR orgone energy produced by the Mega
    Powerwand. "
    Graham ;-)
  5. Robert Baer
    Robert Baer Guest
    ...and twisting the wire makes the electrons twist also???
    Perhaps you should use a Klein bottle as the winding form...
  6. I read in sci.electronics.design that Robert Baer
    I've always wanted to know how to make a non-inductive inductor. Would
    anyone care to make one and measure it?
    Next week: The non-capacitive capacitor. Mica plates and silver
    dielectric.
  7. Jim Thompson
    Jim Thompson Guest
    On Sat, 17 Sep 2005 21:41:30 +0100, John Woodgate
    [snip]
    You bad! Sno-o-o-o-ort!
    ...Jim Thompson
  8. Fred Bartoli
    Fred Bartoli Guest
    "John Woodgate" <> a écrit dans le message de
    But then you'll have to connect them with isolating conductors: a PVC core
    surrounded with a copper insulation.
    The very nice side of this is that the insulation also serves as shielding
    and thus prevents interferences from the bioenergy that's kept inside the
    metallic shielding insulator according to
    http://www.littlemountainsmudge.com/arthoworgoniteworks.htm .
  9. Pooh Bear
    Pooh Bear Guest
    The thought just crossed my mind that the popularity of this kind of junk
    psuedo-science shows that it may actually be like some new religion. Like
    'real' religion it can simply demand belief through faith.
    Graham
  10. Robert Baer
    Robert Baer Guest
    If you use really old and decrepit mica, maybe it will be flaky enough??
  11. Robert Baer
    Robert Baer Guest
    Faith?
    Isn't that the gal that went bonkers?
  12. ehsjr
    ehsjr Guest
    You wind it with anti-matter. Mine measures 223 uWoodgates.
    Trouble is, I can't get the damn thing to resonate with my
    flux capacitor.
    Ed
  13. That's because your flux capacitor has a negative ESR. ;-)
