C
Curbie
I've been chasing this formula around for a couple days and am still
pretty confused, everywhere I turn with this idea just seems to add
more confusion, maybe someone here can help clear this up.
A thread at fieldlines uses this formula to calculate tower wind
loading:
Loads = (air density) X (Area) X (V^2)/2
Air density is .002
http://www.fieldlines.com/story/2009/9/18/201016/375
Wikipedia and Hugh Piggott and Paul Gipe seem to have air density at
~1.2 kg/m^3 (elevation and temperature dependant).
http://en.wikipedia.org/wiki/Density_of_air
Converting 1.2 kg/m^3 to Lbs/Ft^3 is:
=(Air Density {in kg/m^3} * Lbs2kg) / Ft2m ^3
0.0748 =(1.2 * 2.2) / 3.28^3 and NOT .002
So where does this .002 come from???
I tried to track down the meaning of that .002 constant and couldn't,
and in the process found another formula (I think on the NASA site):
Fd = .5 * p * v^2 * A * Cd
Using this formula with both imperial AND metric units I get two
different results that won't convert to each other (39691 Lbs. drag to
5487 kg. drag) the spread-sheet is at the end of this post.
I know I'm goofing up something, does any know what???
Thanks.
Curbie
Calculating Drag Fd = .5 * p * v^2 * A * Cd
Speed of Wind in MPH (Sm) 50 MPH <<< Input
Speed of Wind in kPH (Sk) 80.46744269 kPH =Sm * (Ft2Mi /
Ft2m) / m2km
Velocity of Wind in MPH (Vf) 73.33333333 Ft/s =Sm * (Ft2Mi /
min2h / s2min)
Velocity of Wind in kPH (Vm) 22.35206741 m/s =Vf / Ft2m
Diameter of Rotor in feet (Diaf) 14 Feet <<< Input
Diameter of Rotor in meters (Diam) 4.26721287 Meters =Diaf *
(1 / Ft2m)
Radius of Rotor in feet (Rf) 7 Feet =Diaf / 2
Radius of Rotor in meters (Rm) 2.133606435 Meters =Diam / 2
Area of Rotor in feet (Af) 153.93804 Feet^2 =PI() * Rf^2
Area of Rotor in meters (Am) 14.30139816 Meters^2 =PI() *
Rm^2
Density of Air imperial (Pi) 0.074914141 Lbs/Ft^3 =(Pm *
Lb2kg) / Ft2m^3 Altitude and temperature dependant
Density of Air metric (Pm) 1.2 kg/m^3
Drag Coefficient (Cd) 1.28 Coefficient
Drag in Pounds (Flbs) 39691.04976 Lbs =0.5 * Pi * Vf^2 * Af *
Cd
Drag in Kilograms (Fkg) 5487.50735 kg =0.5 * Pm * Vm^2 * Am *
Cd
Constants
Feet to a Mile (Ft2Mi) 5280 Feet
Meters to Kilometer (m2km) 1000 Meters
Feet to a Meter (Ft2m) 3.28083 Feet
Meters to Foot (m2Ft) 0.3048 Meters
Pound to Kilogram (Lb2kg) 2.20462 Pounds
Seconds to a Minute (s2min) 60 Seconds
Minutes to Hour (min2h) 60 Minutes
loading:
Air density is .002
Thanks.
Curbie
Ft2m) / m2km
min2h / s2min)
(1 / Ft2m)
Rm^2
Cd
Cd
Constants
