I have 4 outputs from different audio sources via aux cable. I'm trying to combine them all into a box and have an easy way to change the audio source. If only one source is going to be used at a time how should I wire everything together?
Should I use a dp4t slide switch like this?
http://www.amazon.com/Position-DP4T...=1439770887&sr=8-1&keywords=dp4t+slide+switch
and would I wire it by connecting the ground on all the aux together and then use one pole for right channel and the other pole for left channel? or do I need a pole for ground as well?
Sorry, i'm fairly new to electronics.
