Will this purchased adaptor be okay?
Discussion in 'Audio' started by JoshuaE, Feb 27, 2018.
  1. JoshuaE
    JoshuaE
    8
    Feb 6, 2018
    I purchased an adaptor for powering a Casio keyboard. The keyboard is rated DC 9 V, 850 mA or 6 batteries "AA." The Adaptor has input as : 100-240VAC 50/60Hz .5a max and an output as : 8v-10v 1A - 2A.
    This adaptor was supposed to work with this keyboard, will there be problems? Also, the adapter is 2mm to long when inserted but the keyboard does play.
    Sincerely,
    Joshua
  2. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    It will be fine.
    JoshuaE likes this.
  3. KJ6EAD
    KJ6EAD
    1,114
    159
    Aug 13, 2011
    FYI, those barrel plugs have two typical lengths, ~9mm and ~11mm. You apparently have a 9mm jack and an 11mm plug but it's usually not a problem having a longer plug unless it's subjected to levering force.
    JoshuaE likes this.
  4. JoshuaE
    JoshuaE
    8
    Feb 6, 2018
    From past research I thought the volts, amps, and watts of the adaptor really had be exact or it would cause problems such as damage over time. Not true?
    Josh
  5. davenn
    davenn Moderator
    13,877
    1,964
    not true
    only parameter that is very important is voltage ( and of course if DC or AC is required)
    the current capability of the PSU needs to be at least that required by the appliance. It doesn't matter if its current rating is much higher
    The wattage is just the product of the voltage and the current being drawn
    W = V x A
    JoshuaE likes this.
  6. JoshuaE
    JoshuaE
    8
    Feb 6, 2018
    Thanks everyone! Also, there is a little blue (led?) light on the base of the adaptor. When the adaptor is plugged in the light is on. When it is unplugged it stays on briefly and than turns off. What is this light for? And I'm assuming the adaptor will still be okay to use with my keyboard?
    JoshuaE
  7. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    I assume that the blue light is to indicate that there is output voltage. It will stay on until the reservoir capacitor discharges.
    JoshuaE likes this.
  8. davenn
    davenn Moderator
    13,877
    1,964
    power on light
  9. JoshuaE
    JoshuaE
    8
    Feb 6, 2018
    Well I have one last question for this topic: :)
    I located an old adaptor with the following attributes:
    input : 120vac 60hz
    output : 9vdc 300ma
    Will this work for the following recapped keyboard :
    If so, is there any reason to not return the purchased adaptor that is :
    input : 100-240VAC 50/60Hz .5a max and an output as : 8v-10v 1A - 2A.
    Thank you,
    Joshuae
  10. davenn
    davenn Moderator
    13,877
    1,964
    the answer is pretty obvious ;) what do you think and why ?
    what is the big difference between them ?
    yes, a big reason and when you work out the difference I asked you about, above
    you will see why you need to keep the new one
    JoshuaE likes this.
  11. JoshuaE
    JoshuaE
    8
    Feb 6, 2018
    The amps aren't right, huh?
    JoshuaE
    davenn likes this.
  12. (*steve*)
    25,497
    2,839
    Correct. The power supply must be capable of supplying (at the very least) the current demanded by the load. Preferably it should be capable of a little more, just so it is not running right at it's limits. If it is capable of supplying even more current, that's fine too.
