Will these light up?
Discussion in 'LEDs and Optoelectronics' started by icor1031, Jan 29, 2012.
  1. Harald Kapp
    11,310
    2,589
    Can't say.
    The rocker switches are designed for 12 V. I assume the "design" is a simple series resistor to limit the current through the LED. At 9 V the LED will probably still light up but not as bright as at 12 V.
    You could just try or ask the seller wheter the LEDs are visible enough at 9 V.
    The part of the rocker switches that switches the power will work at 9 V - this should be no problem.
    Harald
