Wii controller not turning on
Discussion in 'Troubleshooting and Repair' started by Yeah Boi, Dec 22, 2018.
  1. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
    Hi there folks!
    Here I am again with a case coming from my ''To repair'' container. This time it is a Wii controller that does not turn on, simply, no lights blink with good batteries. And I really do not know what causes the problem. The only suspect component is the infrared module that has a weird color, as in the pictures, but if that is the actual problem, why would it cause the controller not to turn on? Thank you very much.
  2. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
    And now I cannot get the pictures to upload...
  3. davenn
    davenn Moderator
    13,496
    1,830
    as you can see, pic's upload OK ... how were you trying to do it ?
  4. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
    There is a problem with my SD card I think.
  5. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
    I try to upload from SD card using a computer, but why is there always an error? Because of .JPG?
  6. davenn
    davenn Moderator
    13,496
    1,830
    well not being by your computer to check .... it's difficult to say what the problem is
    1) for a start, have you down loaded the images from the SD card to the computer ?
    2) is the SD card still in the camera and your camera is connected to the computer via a USB cable ?
    or
    3) are you taking the SD card out of the camera and putting it into a card reader that is either
    a) a slot on the computer ( many laptops have these) ?
    b) an external card reader that has a short USB cable to connect it to the computer ?
    You see, without knowing what you are trying to do, there's many possibilities for problem areas
  7. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
    So when trying to upload them from sd card in-camera connected to USB, it says the file is too big, so what can I do?
  8. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
    Even when compressing them it does nothing.
  9. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
  10. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
    I got it when turning them into smaller images.
    davenn likes this.
  11. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
    Oh yeah, I forgot to mention that the last picture is another controller board, for the comparison.
  12. davenn
    davenn Moderator
    13,496
    1,830
    the last photo was totally blurry, so it didn't really help ;)
  13. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
    So what could the problem be?
  14. davenn
    davenn Moderator
    13,496
    1,830
    Highly unlikely that it would cause a no turn on fault
    VERY CLOSELY check the solder terminals of the battery contacts, it's quite possible there's a dry or cracked joint
    It nay be the actual on/off push button switch ( if it has one)
    Other than a really basic fault along those lines, it's likely to be impossible to repair .... ie. you are not likely to get any of the IC's as spare parts
  15. Yeah Boi
    Yeah Boi
    44
    Mar 24, 2018
    Alright, thank you man. I will do just that. And actually, every button on the controller can be used to boot it. The power button is for the console. And hey, since I think about it, can micro capacitors fail?
