Wifi Transmission; Energy involved in sending a Wifi Signal
Discussion in 'Radio and Wireless' started by akahn430, Oct 29, 2016.
  1. akahn430
    akahn430
    4
    Oct 29, 2016
    I'm currently working on a project involving Wifi transmission. The device needs to send a 1-3 digit number to a computer/phone that is 5-15 feet away. Approximately how much energy will this take to send one number?
    Thank you!
    Austin
  2. davenn
    davenn Moderator
    13,801
    1,941
    hi Austin
    welcome to EP :)
    a very odd question
    A wifi connection is maintained, once a connection is established with or without data being transmitted
    There is continuous background link etc checking going on
    do you really need wifi ? Bluetooth would probably be easier
    so would you like to tell us what you really mean
    Wifi and BT are low transmitter power devices, they will have a minimum power out of maybe around 10 - 20 mW
  3. akahn430
    akahn430
    4
    Oct 29, 2016
    Hi Dave. Thanks for the response.
    Depending on the range that is needed, I suppose it could use Bluetooth.
    What I am trying to get at is: I need to make a system that calculates force in an object when struck (Accelerometer), then sends that force back to a Computer/phone... and it has to power itself, so first, I need to figure out how much energy needs to be generated for each time the Force (1-3 digit number) is sent to the computer, for the system to function.
  4. davenn
    davenn Moderator
    13,801
    1,941
    BT is good for up to 10m
    Power needed in the way u are asking is irrelevent as i said earlier there is going to be continuous power usage. Not just when u send data
  5. akahn430
    akahn430
    4
    Oct 29, 2016
    Thanks again for the response.
    So there would need to be a constant voltage? How would I go about figuring out how much energy has to be generated to power the constant voltage?
  6. (*steve*)
    25,482
    2,830
    You multiply:
    1. the voltage (required by the transmitter and produced by the power source)
    2. by the current (drawn by the transmitter)
    3. by the time (that you want the transmitter operating -- could be minutes, hours, or days)
    That gives you an amount of energy required.
    From that you can choose an appropriate battery.
  7. akahn430
    akahn430
    4
    Oct 29, 2016
    Ah, makes much more sense now. I really appreciate the help!
