Wifi router does not turn on after outage (not what you think please read)
Discussion in 'Radio and Wireless' started by ric_lop_112, Apr 23, 2021.
  1. ric_lop_112
    ric_lop_112
    7
    Apr 23, 2021
    I have a D-Link EXO WiFi 6 Router AX1500 MU-MIMO router. The router is connected to a Surge Protector multi-outlet power strip. Each time power goes out (which is quite common here), the router won't turn back on immediately. I always have to leave it unplugged for more than 3 days. And then it turns on again. This ALWAYS happens. I have tried using different outlets after each outage with no avail. Is there a way to fix this or at least to know why this happens?
  2. Martaine2005
    Martaine2005
    3,596
    979
    May 12, 2015
    Hi, do you leave the router connected to the surge protector strip for those three days?.
    Could be the surge protection component is very slow to return to normal operating resistance.
    Or does it turn on but take three days to re-set?.
    Martin
  3. ric_lop_112
    ric_lop_112
    7
    Apr 23, 2021
    Hi Martin! I unplug everything: power cable from the router and from power strip and even the ethernet cable. Then, I wait for about 3-5 days and then plug everything back again.
  4. Martaine2005
    Martaine2005
    3,596
    979
    May 12, 2015
    Have you tried just plugging the router in without the surge strip?
    Martin
  5. ric_lop_112
    ric_lop_112
    7
    Apr 23, 2021
    Actually, yes. And I wouldn't think the surge strip is the problem, since the modem I also have connected to it immediately turns back on.
  6. Kiwi
    Kiwi
    377
    93
    Jan 28, 2013
    Do any lights come on when the router doesn't go?
    Are you connecting it directly to the other outlets to test without the surge protector?
    Might be time for a new router?
    Also probably get a UPS if you are having power cuts.
  7. dave9
    dave9
    1,145
    311
    Mar 5, 2017
    This is practically impossible. I call shens.
  8. ric_lop_112
    ric_lop_112
    7
    Apr 23, 2021
    No lights come on.
    I have tried without the surge protector.
    I am beginning to consider a new but since it always comes back on...I survive with my internet provider's modem/router while the other one recovers.
    I will start looking for a UPS. Thank you for the suggestion.
  9. ric_lop_112
    ric_lop_112
    7
    Apr 23, 2021
    This really happens to the router!! I do not know why or if I'm doing something wrong, but it happens just as I explained it...
    If it were possible, what would your best guess be?
  10. Ylli
    Ylli
    358
    102
    Jun 19, 2018
    Does this router use a 'wall-wort' type power supply? Try a different (compatible) power supply, or use a voltmeter to check for output on the one you have.
    ric_lop_112 likes this.
  11. ric_lop_112
    ric_lop_112
    7
    Apr 23, 2021
    1. I am a "foreign" language speaker, at least to you since I would assume you don't speak Spanish.
    2. Day=24 hours. Or as we say in Spanish "día".
    3. I have not returned it because, since I live in Puerto Rico, shipping times from and to Amazon are longer. Also, since it always comes back on, well I might as well wait and save myself the longer wait.
    4. I haven't tried the factory reset since I always assumed it was a hardware problem. I will try the reset also. Thank you for the suggestion!
  12. ric_lop_112
    ric_lop_112
    7
    Apr 23, 2021
    Thank you for the suggestion. I will ask someone to look into the power supply and see if that's the problem.
  13. Martaine2005
    Martaine2005
    3,596
    979
    May 12, 2015
    This can only happen by a surge / inrush component not re-setting. Although I have never known one to act like this. But I suppose it's possible.
    I would be tempted to try a little experiment:
    Put the router in the fridge for half hour and then try it.
    If no luck, try heating it with a hairdryer into the air slots for 1 minute. Then try it.
    The assumption would be a protection device failing and not re-setting.
    Martin
    ric_lop_112 and Harald Kapp like this.
