Wide band Ant/ Power decoupling
Discussion in 'Electronic Basics' started by Slav Mitrofanov, Jun 23, 2004.
  1. Dear community,
    could someone help me to find an SMD component(s) to decouple Power (DC) and
    20-3000 MHz with the DC current = 100mA. The problem is that I would like
    to have less than 1dB difference S21 in the rather wide band and usual SMD
    coils give some droppings at their resonance frequencies. I tryed shunt L
    with R 330 Ohm and use two such shunted L in serial. (100 nH and 1uH). But
    it is a bit complicated and some droppings are still more than 1.5dB. The
    question is: are there anything special (some components targeting the
    poblem) designed to feed active antennas and so on?
    Any help or tips are appreciated, thanks.
    Slav.
  2. I think I have found a good solution already. Two, exactly. Ferrite pipe 10
    mm long on a piece of wire: 0.5 dB difference but I loose 1.5 dB of signal.
    And the best solution:
    The Coilcraft 1812 12uH! The coil is on ferrite core and probably losses in
    the core are flattening the plot.
    The result: <-0.1 dB till 500MHz -0.5 dB till 3GHz.
    Would be glad if I could help someone.
    73! Bye.
    Slav (UA3QGN)
