Of ALLLLLLL of your other given numbers . . .this one seems to be THE one .
Since you have a capacitor tester . . . see if 0 decimal 68 ufd or 6.8 ufd is being its magical value ?
Seems like more BULK size would be needed, for that units voltage rating . . .in it being a 6.8 ufd..
BUT the actual function of this capacitor is in it being a series voltage dropping element..
Thereby with an AC impedance of 4680 ohms for a value of .68 , that would let about 50 mils of current be outputted.
Now with 6.8 ufd and its AC impedance equivalency of 468 ohms PLUS a companion 100 ohm series resistor,
THAT combo would let about 500 ma of current through . . . . .more than is needed, to then rectify and filter, in order to be able to snap the 24VDC relay in ,
Plus, there is being a miniscule amount being needed for the secondary power supply level . . . . for the rest of the board.
I'm thereby expecting it to be Decimal 68 ufd.
73's de Edd
