Why to learn Algebra II
Discussion in 'Electronic Basics' started by Ana, Oct 6, 2007.
  1. Ana
    Ana Guest
    I am looking for a person to talk via video conferencing to my Algebra
    II class "Why to learn Algebra II? When will I really use this in
    life?"
  2. As I found it in "science+electronics+_basic_", maybe you should start
    from the VERY basic - "Why to learn _at all_".
    Good luck
    Stanislaw.
    PS. A Hassidic proverb "We always learn."
  3. John Larkin
    John Larkin Guest
    Sad fact is, most people won't use it.
    John
  4. gearhead
    gearhead Guest
    What country do you live in? Your use of the infinitive is not very
    idiomatic, which indicates either that English is not your first
    language, or else you just don't type very carefully.
    But I suppose you want someone to address the students in English,
    because you posted in English.
    You might try the sci.math newsgroup...
    I like solving quirky math problems, like how to weigh a two foot
    piece of thin string when all you have is a U.S. quarter dollar, which
    weighs one fifth of an ounce. You can do it by tying the quarter to
    the end of the string, hanging that end of the string over a waxed
    nail and measuring the vertical deflection (droop) of the horizontal
    section of the string. Using basic algebra and geometry, you can
    calculate the weight of the string to a certain degree of accuracy
    just by measuring the droop.
    I think students will relate to something concrete if you leave out
    moral lecturing and advice about the future, because kids don't live
    in the future.
    Don't listen to the naysayers. This is a very worthwhile project, and
    you may even find that you do indeed get through to the students on
    some level, if you have the right approach.
  5. Ninja
    Ninja Guest
    Ana's email address suggest that she works for the Los Angeles Unified
    School District.
  6. Rich Grise
    Rich Grise Guest
    Because learning _anything_ is a Good Thing. It trains your brain to think,
    and algebra, especially, is broadly applicable in all manner of
    problem-solving.
    If they plan on getting any kind of technical job at all, knowing
    algebra could make the difference in whether or not they get the job,
    which will pay more than a job where you don't have to know anything.
    Not to mention the sheer fun of learning stuff.
    Once, on "are you smarter than a 5th grader", there was a map question,
    something like, "If the scale on the map says 1 inch = 5 miles, then
    how many miles is it between two cities that are 5 inches apart on the
    map?"
    Jeff Foxworty, even though he'd said he didn't know any algebra, stood
    there and did the algebra in his head, and showed his work by doing it
    out loud.
    Cheers
    Rich
  7. Joel Kolstad
    Joel Kolstad Guest
    I'd suggest there's really more arithmetic than algebra. I mean, OK, yes, you
    can make an algebraic equation out of it, but I'm pretty sure most kids
    could've come up with the answer before having taken their first algebra
    class!
    I was always surprised that "story problems" were so dreaded in school -- for
    me they were the most fun, because they showed you what sort of applications
    you could put all this math too (even if many of them were a bit contrived).
  8. The story problems were dreaded because you had to think a little to
    identify the operands and -Horrors!- decide which operation to perform.
    At that age, arithmetic is mostly a pointless ritual one performs to gain
    the approval of adults, so anything that delays the production of a quick,
    correct answer is a threat.
  9. Lord Garth
    Lord Garth Guest
    Let's not confuse Algebra with Arithmetic...
  10. Eeyore
    Eeyore Guest
    I'ts been puzzling me.
    What's the significance of the "II" in Algebra II ?
    Graham
  11. eromlignod
    eromlignod Guest
    If you plan to work in a factory or cook hamburgers as a career, then
    no, it isn't very useful.
    If, on the other hand, you plan to study virtually any science or
    economic major in college, then it is a good idea to take it in high
    school. A beginning freshman in engineering is expected to have
    already taken algebra and trigonometry and to be ready to start off
    with calculus I. Algebra and trigonometry are considered remedial
    classes in engineering.
    Since science programs rely on the building of prerequisites, having
    to learn algebra in college could set you back a semester.
    Don
    Kansas City
  12. Rich Grise
    Rich Grise Guest
    Probably when they get to exponents, logs, quadratics, and things like
    "linear algebra".
    I wonder if OP is following the thread?
    Rich
  13. What do you THINK it means? It is a second year of the subject, like
    all other 'II' courses.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  14. Eeyore
    Eeyore Guest
    That style of nomenclature nor 'electronics 101' and the like isn't used in the
    UK but thanks for the explanation.
    So how many years Algebra is typically taught in 'high school' as you call it in
    the USA ?
    Graham
  15. Don Bowey
    Don Bowey Guest
    In the 50's there was one algebra class in my HS, but we were allowed to
    take courses at the U of Oregon and were given both HS and college credit
    for them.
  16. Rich Grise
    Rich Grise Guest
    In the HS I went to, a year; the following year we started getting
    into differential calculus. But college is generally measured in
    "terms" or "quarters" or "semesters" - I can't imagine spending a
    whole year on Alg. I.
    Cheers!
    Rich
  17. Eeyore
    Eeyore Guest
    So, to return to my original question .... how many years did you study Algebra at
    'high school' ?
    I'm doing my best to recall my own education in detail for comparison. I know we
    did Geometry at 'Prep School' - ie. age up to 11. Maybe just in the last year -
    from age 10 to 11. I'm not quite sure if we covered basic Algebra at that time.
    I think Algebra was a standard component of the Mathematics we studied from age 11
    - 18.
    In the later years of that we were of course covering Calculus (differential
    equations, integration etc) and the like.
    Graham
  18. Eeyore
    Eeyore Guest
    Geometry, Algebra and Calculus were simply components of the Mathematics we were
    taught over the years with increasing emphasis on the hard stuff as you got older !
    At the 'O Level' examinations (taken age 16 normally) ..........
    http://en.wikipedia.org/wiki/General_Certificate_of_Education
    I took 2 exams in Mathematics. Maths and 'Addtional Maths'. The 'additional' bit
    basically being to prove that you were a 'clever clogs' with the difficult bits like
    calculus.
    At 'A level' I took the 'Pure and Applied Mathematics' exam. This is the one designed
    for 'scientists'. It's tough ! I decided not to take the additional 'S level' exam in
    Maths (way too esoteric) although I was in the relevant 'stream' to do so, choosing
    only to take (and pass of curse ) the ultra-hard 'S level' Physics.
    Anyone who passed an 'S level' was 'mentioned in despatches' so to speak at the
    soonest possible school assembly. We were considered 'heroes' of a sort.
    Graham
  19. redbelly
    redbelly Guest
    To answer your question, it's standard in the U.S. to take 2 years of
    algebra in high school. Alg. 1 in 9th grade, Alg. 2 in 11th grade,
    with a year of Geometry in between. Trigonometry (or "Pre-Calculus")
    is taken in 12th grade.
    That being said, many kids take an "advanced track" in math, where
    everything is shifter 1 year earlier. In that case, calculus is taken
    in 12th grade.
    Mark
  20. Lord Garth
    Lord Garth Guest
    My math education sequence was Algebra I, Algebra II, Geometry,
    and lastly Trig / Analysis.
    I changed high schools in 10th grade due to the math teacher for
    algebra II not actually teaching algebra. The idiot had us performing
    arithmetic calculations. This caused me to take summer courses to
    catch up as it were. I was back on track after that incident.
    I believe his name was Mr. Carpenter but I am not at all certain
    as my middle age brain has flushed that jerk from memory.
