John G
From what I have been able to sift from the crap posted everytime thisBarry Jones said:That's an Australian term, right? Multiple Earthed Neutral? How is
that implemented?
I've seen earth potentials range over a few volts within a few tens of
meters. What does that do to the neutral line?
or similar questions come up....
The Australian MEN system is about the same as the US system as far as
Grounds ar concerned.
The neutral which of course is the centre of a WYE circuit 230/400 volts
is tied to a ground stake at various points of the system. There is a
pole transformer outside my house and the neutral is securely grounded
there.
Then the Neutral and a houshold ground stake are tied together in the
building distribution/entry box. After that there is a neutral and a
ground (and a hot of course) to every General Purpose Outlet thru the
appropriate breakers of generally 16 amps. Although I have 3 phase at
the box only one phase is used in the house, the 3 phase is just for the
air con. Most houses would only have 1 phase at GPOs so you could not
get 400 volts by using 2 outlets like I have heard of being done in USA
to get 220volts.
There are no fuses in plugs as there are in the UK and many new small
appliances are double insulated and do not have a ground connection a
all.
The ground was NEVER used in this country, as a current carrying
conductor, like it was in Edison USA.
