R
Robert Baer
....or OR and NOT..
How about a BUT gate, or a MAYBE gate?
---> BUT NOT AND MAYBE XOR ?
Robert said:...or OR and NOT..
...and of course the inevitable DON'T gate.Or the WHAT gate, like, I can't BELIEVE you'd give me that input.
Or the ALREADY and OY gates. e.g. Y = (B XOR C) ALREADY.
And of course back home in Lancashire there's the HAPPEN gate: Y = A + B
HAPPEN.
Usually when I say that in a meeting people understand it to be dead-
pan sarcasm.
However, I don't know how to inflect that in a newsgroup post.
Love it! (chuckle)Paul said:Or the WHAT gate, like, I can't BELIEVE you'd give me that input.
HAPPEN.
That is the exclusive domain of the wife!krw said:..and of course the inevitable DON'T gate.
tempus fugit said:This brings up something I was wondering about also. What if your design
requires about 20 - 30 signals to be OR'ed together? The most I could find
was an 8 input OR gate, so I suppose you could use several of these, but it
would increase propagation delay considerably. I just ended up using tons of
diodes and ORing the signals that way, but is there a more efficient way to
do it?
UK, perhaps the WON'T gate is a better term for the digital versionThat is the exclusive domain of the wife!
Wire-OR open collector drivers.This brings up something I was wondering about also. What if your design
do it?
John Barrett said:diode-or just make sure they dot drop the voltage below TTL threshold
(which is why they are not generally used for OR gates)
Joel Kolstad said:Using your favorite CPLD, you can probably OR together many dozens or even
hundreds of signals in no more than 10ns or so (say 20-30ns for "hundreds")...
Another alternative, in a synchronous system, is of course to just register
the outputs of some blindingly fast logic gate... so you can OR together, say,
hundreds of inputs coming in at, say, 200MHz so long as you can wait perhaps
3-4 clock cycles for the output to be valid...
Once upon a time, when DTL was king, there were extenders - so onetempus said:This brings up something I was wondering about also. What if your design
do it?
Is that as bad as the CAN'T gate?krw said:UK, perhaps the WON'T gate is a better term for the digital version
of the "inoperational amplifier".
krw said:Wire-OR open collector drivers.
No; you did it right - you do need the diodes (or equivalent gatestempus said:a 1
tons of
I just found a circuit like what I think you are describing, but although it
is called wired OR, it is actually a wired AND circuit, since the output is
high only when all the inputs are high. My design required that the output
be high when any of the inputs were high. Is there a way to do this (without
using dozens of diodes)? I also needed the diodes for DC blocking, since a
high on any one of the data lines would also send a high to the ouputs of
the other data lines.
[/QUOTE]krw said:Wire-OR open collector drivers.
Actually, what you said is ratheer close to the truth...krw said:Sorta like; "Constants aren't and variables won't."
