Why OR gates?
Discussion in 'Electronic Design' started by eromlignod, Mar 22, 2007.
  1. eromlignod
    eromlignod Guest
    Hi guys:
    Here's just a simple, silly question from a non-EE that probably has a
    simple answer.
    If I have several TTL logic outputs that I want to "OR" together, so
    that any of these will drive the output of the OR gate, why can't I
    just connect the output wires together physically, merging them into
    one wire, without using the gate?
    One reason I can think of is that it avoids the case where two
    connected wires are high at the same time. But if I ensure that this
    cannot happen due to my upstream design (like a decoder), do I still
    have to use the OR, or can I merge the outputs?
    Don
  2. Tam/WB2TT
    Tam/WB2TT Guest
    If you tie the outputs of two TTL gates together, and one output is a 1 and
    the other a 0, you end up with a short corcuit between VCC and ground
    through the gates. For a 74Fxxx, for instance, you will draw about 100 ma,
    and the resultant output will be neither a 1 or a 0.
    Tam
  3. eromlignod
    eromlignod Guest
    OK. I knew it was something stupid. I was thinking that gate outputs
    are high-impedance, but it's the inputs that are hi-Z. Duh.
    What I'm trying to do it select one of three inputs without using a
    lot of chips, or wasting a lot of gates. I know that there are MUX's,
    like the 74153 that have dual 2 to 4 selectors, but I hate to waste
    the second MUX. I was hoping to use three AND gates with 3 enable
    lines, but then if I need an OR gate, that's another chip...probably a
    quad.
    Don
  4. If you'd asked where this belongs, sci.electronics.basics I'd take
    a shot at answering it. But since you can't bother to find the right
    newsgroup, I won't.
    This is not a design question, it doesn't belong in a newsgroup about
    design.
    Michael
  5. Fred M
    Fred M Guest
    Well, sorta. TTL inputs are medium-high (Z loading on an output is a
    factor based on number of inputs driven).
    CMOS inputs are quite high (only distributed capacitance of multiple
    traces/inputs is a rise/fall time factor).
    Fred
  6. Fred M
    Fred M Guest
    Oops, sorry Michael - meant to reply to author.
  7. Fred M
    Fred M Guest
    Fred
  8. GregS
    GregS Guest
    DTL is what you seem to want to do. You can add steering diodes.
    greg
  9. Of course you can. It's a very common construct called "Wired OR".
    No problem with open-collector outputs. Otherwise just add some diodes.
    Since you are using TTL, and since TTL usually has OC outputs (but do check
    the datasheets of your chips to make sure), there is no problem. With
    push-pull outputs (such as CMOS, like the 40xx or 74HCxx series) what you
    have in mind is not only bad design, but it simply won't work at all.
    robert
  10. John Barrett
    John Barrett Guest
    diode-or :) just make sure they dot drop the voltage below TTL threshold
    (which is why they are not generally used for OR gates)
  11. Guest
    This is badly phrased. There are TTL parts with open-collector outputs
    - the SN7406 - for example, and these can be used to build wired-OR
    functions.
    http://focus.ti.com/docs/prod/folders/print/sn7406.html
    Most TTL parts have a totem-pole output which can both source current
    (1 or high state) or sink current ( 0 or low state) and you shouldn't
    use them for wired-ORs,
    Emitter-coupled logic (ECL) uses an NPN transistor as the output
    driver, and can only source current - it relies on a pull-down
    resistor (usually 50R to -2V) to provide the pull-down current to
    generate a low (0) output, and all ECL parts can be used to produce
    wired-ORs, though it isn't a good idea if the gates being OR'd are
    more than an inch (a few centimetres) or so apart.
  12. Rich Grise
    Rich Grise Guest
    If you invert the inputs, turn the diodes around into a wired-and, and
    invert the output, it achieves the same thing (by DeMorgan's theorem),
    and has a better chance of working with TTL, which has strong pulldowns
    but weak pullups.
    Cheers!
    Rich
  13. I did not know that.
  14. Tam/WB2TT
    Tam/WB2TT Guest
    This won't work into TTL because it leaves the input to the next stage
    floating, which is a mostly ONE. If you add a pulldown of sufficiently low
    value you won't be able to drive it. This basic configuration will work if
    you use resistors, instead of diodes, and connect them to the base of a
    transistor. Connect another resistor from collector to ground. What you have
    now is a NOR gate; so, you need to invert that.
    This will work. Notice, Rich said to invert the signals. You will need a
    ~10K resistor from the diode outputs to VCC.
    Tam
  15. Tam/WB2TT
    Tam/WB2TT Guest
    You didn't know that because it is NOT true.
    Tam
  16. I would not think this reliable as the diode puts you at the threshold
    instead of in the low region.
    Best, Dan.
  17. Rich Grise
    Rich Grise Guest
    Eek. You're right. I guess it worked for me before because I didn't know
    that, much like the bumblebee doesn't know it's impossible for him to
    fly. ;-)
    (I probably just lucked out on margins & stuff.)
    Thanks!
    Rich
  18. OK, this is your design and I won't comment on it.
    But from my short (25 years plus) time spent in various designs I can
    assure you one thing. Mr. Murphy is a constant companion so designing to
    evade his inerference is futile (Star Trek). The problem is to ensure
    that your signals don't create low-high couples, and for this you have
    the OR gate as a bouncer.
    Not only that, but it is a component in Boolean logic, and we love to
    use math before assembly.
    Have fun
    Stanislaw
    Slack user from Ulladulla.
  19. Well, I'm only marginally right. :)
    Best, Dan.
  20. Usually when I say that in a meeting people understand it to be dead-
    pan sarcasm.
    However, I don't know how to inflect that in a newsgroup post.
