[email protected]
I'm sur y'all remember when I got edumacated thar my invention had been inventd before and is known as a Dickson pump charge. Thos who were in that will remember it is a single ended voltage doubler which can be stacked on top of its input to make a voltage tripler.
People admonished me that capacitively coupled voltage multipliers are not very good with current, but I beg to differ. And to also should get an ideawhat kind of capacitors I am talking here. In its current build it has on the top 8,200 uF, the bottoms are 10,000 I think. I decided to have the topones be lower just for those awkwark power up moments. Justin Case, y'know? Doesn't matter, at 6 Khz they could be 470s if they could handle the current. The Xc means noting here.
those huge capacitors are put into power supplies that use oscillarors or just raw transformers off the wall. In either case, every ampere that goes through the circuit is stored and discharged by the capacitors. The olnly diffeence here is that the capacitor is floating. Itis a similar concept to acoupling capacitor. It can do it. I don't kno23 if I'll get the current out of it I want in its preent build, but the most that cna happen is the smoke comes out. I'll do it outside.
So much for that. Let's jusr assume I have the capacity to get triple voltage. That is 36 volts.
The original amps that ran off of 12 volts were patterned off of the old Mindblowerr car speakers. I'll not go into all the details of those at the moments but here is the basic circuit :
https://dl.dropboxusercontent.com/u/29948706/mb01.jpg
In a way it's like a tube amp, but you're driving the secondary directly. you can actually call the output stage DC coupled. That DC coupling is not all it's cracked up to be. Yes there is no better way to get good bass and maintain the dampering factor, but some people think DC coupling means all the way from the source. Never did.
Anyway, since I feel not like building a suitable car amp to feed the few (two actually) input transformers I have, I am going to have to do some designing. Not much, but no more transformers. If I can't do this, well, **** me.
So I come up with this :
https://dl.dropboxusercontent.com/u/29948706/mb02.jpg
Understand something here, because the drive has to go negative without a negative source, what do you do ? In the first one the transformer resolves all those issues, but we do not want the transformer.
To DC couple it would require a negativ source, and before you go into thatonchip magic using only a 0.1 uF on the outside, remember this is audio, hopefully esoteric, high end audio.
The MOSFETs shown, well you know how they go, the sources go to the junctions of R10, 11 and 13, 12. Those give it voltage gain. The depletion moe FETat the input there splits the phase for it, and after the capacitive coupling, bias is dealt with without interference from the DC components produced by non-linearities in the output devices/drivers.
In such a circuit, there is no room for an enitter resistor. the voltage drop is quadruple3d so it is extremely inefficient for the design's intent, so there are none. The only good thing here is that for common mode DC, the choke's windings themselves will provide some degenration of the DC withoutgreatly affecting the signal.
That FET at the beginning of it, it doesn't have to come so fast. Once the phase splitter is there, I will have to combine any feedback. It might be easier as well as better to keep the two feedback paths separate farther back in the chain. I don't like dealing with the thermal stability of something DC cpoupled that far back, but you know, if it gets the audiohead goldenears award I get to sell them for a shitload of money.
Think of these audiophiles out there who buy my amps. Dem niggas pulls up with "BOOM mufufa BOOM mufaka BOOM mufoika" and Whitey is up there smailing,right biotch ! = fucking Beetoven ten times louder. All the kids in the neighborhood gain ½ an IQ point and everybody happy.
Sometbing like that.
Thank you for your time, we have downloiaded all your bank money.
Also, if anyone has any more sonically pure ideas on how to drive this output choke type circuit, please do.
