My evilness shows no bounds
At present I'm pretty sure you see posts I delete (probably showing up as a deleted post). This retains the apparent post counts, but some boards make these totally disappear, which again breaks any sequential numbering (or where I've seen it used it has).
However, each post does have a unique post number. This remains the same even if you (well, I, but you get the point) move the post. Mostly you only see that when you quote a message and it appears in the quote tag. But it also appears if you search for posts. Unfortunately, we don't have a "permalink" to make it easy for people to point to a particular post without using the quote.
Code:
[ QUOTE=KJ6EAD;1458138 ] Post #8 [ /QUOTE ]
The number 1458138 is a unique number for your post (It may also mean it was the one million, four hundred and fifty eight thousand, one hundred and thirty eighth post.)
That can also be used to generate a link to your post as a url (but it's not obvious how). It's also not particularly useful because the URL changes if I move the thread, and it is sensitive to the page the thread is on
Having a permalink option would be cool, but I don't know if the vBulletin software supports it.
(some Googling later)
Yeah. Apparently if the post numbers are turned on, they are a permalink. Unfortunately, it would probably mean people will refer to the post number rather than using the link it provides.
I've tried some cleverness to manually generate urls in the form that I *think* the permalink uses, but I can't get them to work. So, sorry, I can't offer you some secret magic to amuse your friends and confound your enemies!
Hang on, let's try this
First use the following as a base...
Code:
https://www.electronicspoint.com/forum/showthread.php?p=
then add the post number (e.g.)
yielding
this or
https://www.electronicspoint.com/forum/showthread.php?p=1458138 or
Code:
