JosephKK
glen herrmannsfeldt [email protected] posted to
sci.electronics.design:
While i have not see one, there is nothing that prevents it
technologically. I have seen receivers that can receive the entire
AM band (in stereo as broadcast) at the same time. I have seen
receivers that receive over half of the FM band (in stereo)
simultaneously. Only ADC, DAC, and compute power available preclude
block conversion. Dig around bit on software defined radios and you
can find the done devices that i have found.
Gary Tait wrote:
(snip)
I remember in the days of UHF getting more popular, and using
a converter box that output on VHF channel 3. This can be done
with the appropriate mixer and LO, without converting the input
to baseband. It does involve tuned circuits, but does not
convert all (70) UHF channels to be tuned on a (12 channel)
VHF tuner.
I believe there were/are block converters from cable channels
to UHF which do convert all at once. Most cable boxes don't
do that, though. Early (analog) ones did the down conversion
similar to the UHF conversion described above. Most now likely
go to baseband and then remodulate for those without video inputs.
The distinction between 'tuner' and 'converter' is fuzzy.
I don't believe that there is a convenient way to block convert
the ATSC input to NTSC output. One could build a box with
multiple tuners, decoders, and modulators but I doubt that
would be for the consumer market.
