Peter said:
I took calculus before, but never understood the theory behind it and how
to apply it.
One thing I never understood is: why is the dervivative of position
velocity and the second dervivative of position is acceleration?
Is this something you're to memorize or is there an actual reason behind
it?
Saying "derivative of position" is incomplete. You meant to say: "derivative
of position with respect to time"
Although it is obvious, but it is the key to understand why it is like that.
Think of it this way:
Suppose you were moving for 20 seconds.
At the 10nth second, you decided to figure out how fast you are moving at
THAT EXACT SECOND.
You do this: Measure the distant measured between second 10 and second 10.01
for example. Lets say you travelled 0.02 meters. Then your speed is
0.02/0.01 (change of distance with respect to time). For more accurate
results, you can meaure distance tranvelled between the seconds 10 and
10.00001, and find that distance by 0.00001. . . . the smaller the "time
window", the more accurate your CURRENT speed is. As this "time window" gets
smaller and smaller, you'd be taking the derivate at that point. WHY? Simply
because they called that process a derivative. Later on, they could prove
that faster way than doing that process exist to find the same value!!
So, change of distance with respect to time is speed (they called it speed
instead of saying change of distance with respect to time. Instead of
saying: I cover 50 miles each hour, I say my speed is 50 miles/hour)
Now, same logic goes for acceleration. If between the seconds 10.00 and
10.01 your speed was lets say 10 meters/second. Then between 10.01 and 10.02
your speed was 11 meters/second or maybe 9 meters/second. So we are looking
at a change in speed over a time of 0.01 second. This change of speed is
called acceleration. Now, by how much did your speed was changing AT the
second 10.01s ? What you can do is take a time window of 0.0000001 and
measure your velocity at 10.01 and then at 10.0100001, then take that value
and divide it by the "time window" which is 0.000001. For more accurate
results, take a smaller window. As the time window is very very small, you'd
be getting more accurate results. They called the process of making the
"time window" to be very very small and finding the corresponding speeds,
then dividing the change of speed by the very small time window a
derviative. Later, they found out they can do shortcuts to make this process
simpler.
I hope that helps, although boring.
