Why doesn't my shift register work?
Discussion in 'General Electronics Discussion' started by leonheard, Dec 31, 2014.
  1. leonheard
    leonheard
    12
    Jan 25, 2013
    why my shift register doesnt work?!
    Hi!
    I bought an TC74HC595P (Toshiba) 8 BIT register... the datasheet:
    http://pdf1.alldatasheet.net/datasheet-pdf/view/31766/TOSHIBA/TC74HC595.html
    i want to use it without a microcontroller all with switch buttons ( for educational purposes only doesnt need to work 100%) since i am very interested in learning about serial to parallel data in "real time".
    like in this tutorial video:
    this is my schematic:
    http://s10.postimg.org/uscnqogw9/schematic123.jpg
    it doesnt work like it suppose to work, it gives me random outputs! :/
    is something wrong with:
    my schematic?
    IC ?
    debounce?
    i tried to fix this for 19 hours now and nothing :(
    i would appreciate your help...
    thanks! :D
  2. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    Try shorting out the LED's on the input pins. The voltage drop on the LED may be preventing the input from getting a low enough voltage to be a logical ZERO.
    Arouse1973 likes this.
  3. leonheard
    leonheard
    12
    Jan 25, 2013
    thanks for your help! i made a simple monostable vibrator with an ic555... now my shift register WORKS 100%!:p i hope this helped someone else with same problem...
