S
Simoc
Hello,
Well, I've got my first microcontroller project *almost* working
So this should be some kind of burglar alarm. It is otherwise working
well,
but it tends to freeze when it's counting either arming or alarm
delay.
It doesn't freeze everytime, but often, say, averagely every other
time.
The program code below might be pretty long and complicated to
analyze,
but if someone would bother to tell why does that freeze, I'd be
extremely
grateful =)
The freezing happens when in "arming" or "triggered" loop on
the main program, the variables "armDelay and "alarmDelay" are
decremented
by Timer 1 overflow interrupt.
Btw, as I'm still a newbie on both programming and using
microcontrollers,
I know that the program might be _far_ from ideal/optimal design, but
I'm
currently mostly interested just about that why does it freeze.
Thanks in advance for everyone having any thought...
#include <mega16.h>
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
#include <delay.h>
#include <lcd.h>
#asm
.equ __lcd_port=0x15 ;PORTC
#endasm
#define BLINKERS PORTA.0 //Blinkers (turn signals) control relay
#define HORN PORTA.1 //Horn control relay
#define CALL PORTA.2 //Call -signal for attached cell phone
#define IGNITION PORTA.3 //Ignition relay
#define SENSOR PINB.7 //Sensor input
#define POWER PINB.6 //Ignition lock state input (1-active)
// global variables
char key='A'; //tells the number of pressed key
int m=4; //keypad row multiplexer
unsigned char intToChar[4]={'A'}; //integer to be displayed is
converted to char in this variable
eeprom int correctCode[4]={2,3,4,5}; //the correct code is stored in
this table
int code[4]={'A','A','A','A'}; //entered code is stored in
this table
int newCode[4]={'A','A','A','A'}; //fed new code is stored in
this table before verification
int p; //code input pointer
int t; //code comparison pointer
char c; //code[4] resetting pointer
bit enterCode=0; //if 0, "enter code" displayed
bit correct=0; //turns 1 when correct code entered
int okKey=0; //tells what to do when # (OK-key) pressed:
//if 0, code[4] will be compared to correctCode and
correct=1 if matched
//if 1, code[4] string will be converted to integer
and stored in setAlarmDelay
//if 2, code[4] string will be converted to integer
and stored in setArmDelay
//if 3, code[1] will be stored in
autoArm
//if 4, code[4] will be stored to newCode[4] and re-
entering requested
//if 5, code[4] will be compared to newCode and
stored in correctCode if matched
bit horn=0; //horn cycler
int hornCycle=3; //horn on-off cycle interval, to be
decremented by timer
int callTime=0; //call-signal pulse timing
eeprom int setArmDelay=20; //delay before arming
int armDelay=0; //variable to be decremented by timer
eeprom int setAlarmDelay=30; //Delay before activating alarm
int alarmDelay=0; //variable to be decremented by timer
eeprom int arming=0; //sets 1 when in "arming" -loop
eeprom int armed=0; //sets 1 when in "armed" -loop
eeprom int triggered=0; //sets 1 when in "triggered" -loop
eeprom int alarm=0; //sets 1 when in "alarm" -loop
bit settingsCodeQuery=0; //sets 1 when in "settings code query" -loop
of settings entry
bit cancel=0; //if 1, settings will be cancelled
bit settingsEntry=0; //sets 1, when in settings mode
bit settings=0; //sets 1, when correct code entered in
settingsCodeQuery
eeprom int autoArm=1; //sets 1, if "auto arming" -feature is
enabled, 0 if disabled
bit noAutoArm=1; //Turns 1 when disarming, reset to 0 when
POWER==1. if 1,
//auto arming temporarily disabled
until reset
//(in order to prevent auto arming
right after disarming before ignition
//has been turned on one time)
int n; //number of digits fed in code[4] in delay
settings
long int r; //calculated (n-t)th power of 10
//(used when converting a string into an
integer in delaysettings)
int e=0; //the exponent of 10 of a digit being
calculated (n-t)
integer in delay settings)
void nollaus() //resets code[4], its display, and input
pointer p
for(c=0;c<4;c++)
code[c]='A';
p=0;
lcd_gotoxy(11,1);
lcd_putsf(" ");
void keypad()
if(enterCode==0) //displays "enter code to arm" if enterCode==0
lcd_gotoxy(0,0);
lcd_putsf("enter code to arm [ ]");
enterCode=1;
lcd_gotoxy(11,1);
else if(key!='A'&&settings==0) //inputs the value of key to code[p],
if changed, displays it or '*', increments p
code[p]=key;
key='A';
itoa(code[p],intToChar);
lcd_gotoxy(p+11,1);
if(okKey==1||okKey==2||okKey==3) //if in delay or auto
arming setting mode, the number is displayed
lcd_puts(intToChar);
else //otherwise
'*' is displayed
lcd_putchar('*');
delay_ms(200);
if(p<3&&okKey!=3) //p incremented,
provided p<3 and not in auto arming setting mode
p++;
else if(key!='A'&&settings==1) //if improper key pressed in
"settings" mode, its value is cleared from "key" immediately
key='A';
// External Interrupt 0 service routine (the left column of the
keypad)
interrupt [EXT_INT0] void ext_int0_isr(void)
SREG=0x00; //interruptions denied
delay_ms(140); //debouncing
if(PIND.2==0) //(the service routine will be proceeded if
the int0 input is still active after 140ms delay)
if(PORTD.4==0) //the 1st row of the keypad (1)
if(settings==0)
key=1;
if(settings==1) //alarm delay setting
settings=0;
lcd_clear();
lcd_putsf("Set alarm delay [");
itoa(setAlarmDelay,intToChar);
lcd_putsf("]");
lcd_gotoxy(10,1);
lcd_putsf("[ ]");
okKey=1;
if(PORTD.5==0) //the 2nd row of the keypad (4)
if(settings==0)
key=4;
if(settings==1) //code change mode
settings=0;
lcd_gotoxy(0,0);
lcd_putsf("enter new code
okKey=4;
if(PORTD.6==0) //the 3rd row of the keypad (7)
key=7;
if(PORTD.7==0) //the 4rd row of the keypad (*)
if(p==0&&settingsEntry==1) //if no digits fed in
settingsEntry mode, cancelled
cancel=1;
if(settingsCodeQuery==0)
cancel=0;
okKey=0;
settings=0;
settingsEntry=0;
enterCode=0;
nollaus();
if(p>0) //if digits fed in code[4], the
last will be cleared
if(code[p]=='A')
p--;
lcd_gotoxy(p+11,1);
lcd_putsf(" ");
code[p]='A';
lcd_gotoxy(p+11,1);
SREG=0x80; //interruptions allowed
// External Interrupt 1 service routine
interrupt [EXT_INT1] void ext_int1_isr(void)
if(PIND.3==0) //
if(PORTD.4==0) //the 1st row of the keypad (2)
if(settings==0)
key=2;
if(settings==1) //arming delay setting
settings=0;
lcd_clear();
lcd_putsf("Set arming delay[");
itoa(setArmDelay,intToChar);
lcd_putsf("]");
lcd_gotoxy(10,1);
lcd_putsf("[ ]");
okKey=2;
if(PORTD.5==0) //the 2nd row of the keypad (5)
key=5;
if(PORTD.6==0) //the 3rd row of the keypad (8)
key=8;
if(PORTD.7==0) //the 4rd row of the keypad (0)
key=0;
// External Interrupt 2 service routine
interrupt [EXT_INT2] void ext_int2_isr(void)
if(PINB.2==0) //
if(PORTD.4==0) //the 1st row of the keypad (3)
if(settings==0)
key=3;
if(settings==1) //auto arming
setting
settings=0;
itoa(autoArm,intToChar);
lcd_gotoxy(0,0);
lcd_putsf("Auto arming:[");
lcd_putsf("] 1n,0ff[ ] ");
okKey=3;
if(PORTD.5==0) //the 2nd row of the keypad (6)
key=6;
if(PORTD.6==0) //the 3rd row of the keypad (9)
key=9;
if(PORTD.7==0) //the 4rd row of the keypad (#)
t=0;
if(p==0&&arming==0&&okKey==0&&settingsEntry==0) //if
no digits fed in disarmed mode
settingsEntry=1;
lcd_gotoxy(0,0);
lcd_putsf("settings, enter code [ ]");
while(1) //loop: settings code
query
settingsCodeQuery=1;
keypad();
if(cancel==1) //if
cancel==1, settings will be cancelled
cancel=0;
settingsEntry=0;
break;
if(correct==1) //if
correctCode entered, entered to settings
mode
correct=0;
settings=1;
lcd_clear();
lcd_putsf("Settings");
delay_ms(2000);
lcd_clear();
lcd_putsf("1:alm d 2:arm
d3:AutoArm 4:code");
break;
denied
if(okKey==0&&p!=0&&settings==0) //entered code is
checked if it is correct
while(1) //comparing entered code to
correctCode
if(code[t]!=correctCode[t]) //
if mismatched, "wrong code" displayed
if((armed==1&&triggered==0)||
arming==0)
lcd_clear();
lcd_putsf("Wrong code");
else
lcd_gotoxy(0,1);
delay_ms(2000);
nollaus();
break;
if(t==3) //if all 4
characters matched, correct=1
nollaus();
correct=1;
break;
t++;
if(okKey==4) //entered code will be copied to
"newCode" and re-entering
requested
if(code[3]!='A')
for(t=0;t<4;t++)
newCode[t]=code[t];
lcd_gotoxy(0,0);
lcd_putsf("verify new code");
nollaus();
okKey=5;
if(okKey==5) //entered code compared to
newCode and stored in correctCode if matched
if(code[3]!='A') //if 4 digits fed
while(1)
if(code[t]!
=newCode[t]) //if mismatch occured
lcd_clear();
lcd_putsf("mismatch
nollaus();
delay_ms(2000);
okKey=0;
settingsEntry=0;
break;
if(t==3) //if all 4 digits matched
nollaus();
for(t=0;t<4;t++)
correctCode[t]=newCode[t];
lcd_clear();
lcd_putsf("changed");
nollaus();
delay_ms(2000);
okKey=0;
settingsEntry=0;
break;
t++; //t
incremented if digit t matched
if(okKey==2&&code[0]!='A') //entered string will be
converted to integer and stored in setArmDelay
n=3; //identifying the
number of fed digits
if(code[3]=='A') //
n=2; //
if(code[2]=='A') //
n=1; //
if(code[1]=='A') //
n=0; //
armDelay=0;
for(t=0;t<=n;t++) //each digit is
multiplied by its power of 10 and added to armDelay
r=1;
for(e=n-t;e>0;e--) //(n-t)th
power of 10 is calculated and stored in r
r=10*r;
armDelay=armDelay+(code[t]*r); //
digit t multiplied by its power of 10 (r)
setArmDelay=armDelay; //the value
calculated in armDelay is stored in setArmDelay
itoa(setArmDelay,intToChar); //the
stored setArmDelay value is displayed
lcd_gotoxy(0,0);
lcd_putsf("Arming delay changed:[");
lcd_putsf("] ");
okKey=0;
settingsEntry=0;
delay_ms(2000);
nollaus();
if(okKey==1&&code[0]!='A') //entered string
converted to integer and stored in setAlarmDelay
if(code[3]=='A') //
n=2; //
if(code[2]=='A') //
n=1; //
if(code[1]=='A') //
n=0; //
alarmDelay=0;
multiplied by its power of 10 and added to alarmDelay
r=1;
r=10*r;
alarmDelay=alarmDelay+(code[t]*r); //
setAlarmDelay=alarmDelay; //the value
calculated in alarmDelay is stored in setAlarmDelay
itoa(setAlarmDelay,intToChar); //the
stored setAlarmDelay value is displayed
lcd_gotoxy(0,0);
lcd_putsf("Alarm delay changed:[");
lcd_putsf("] ");
okKey=0;
settingsEntry=0;
delay_ms(2000);
nollaus();
if(okKey==3&&(code[0]==0||code[0]==1)) //
code[0] will be stored to autoArm
autoArm=code[0];
noAutoArm=1;
lcd_clear();
if(autoArm==0)
lcd_putsf("Auto arming disabled");
if(autoArm==1)
enabled");
okKey=0;
settingsEntry=0;
delay_ms(2000);
nollaus();
if(triggered==1) //if in
"triggered" mode, "enter code" displayed
lcd_gotoxy(0,1);
lcd_putsf("enter code[ ]");
if(armed==1&&triggered==0) //if in
armed mode, "enter code to disarm" dispalyed
lcd_gotoxy(0,0);
lcd_putsf("enter code to disarm
if(arming==0&&settingsEntry==0&&settingsCodeQuery==0) //if in disarmed
mode
enterCode=0;
if(settingsCodeQuery==1) //if in settings
code query mode, "settings, enter code" displayed
lcd_gotoxy(0,0);
// Timer 0 overflow interrupt service routine
interrupt [TIM0_OVF] void timer0_ovf_isr(void) //keypad rows
multiplexed
PORTD.4=1;
PORTD.5=1;
PORTD.6=1;
PORTD.7=1;
if(m==4)
PORTD.4=0;
if(m==5)
PORTD.5=0;
if(m==6)
PORTD.6=0;
if(m==7)
PORTD.7=0;
m++;
if(m==8)
m=4;
// Timer 1 overflow interrupt service routine
interrupt [TIM1_OVF] void timer1_ovf_isr(void)
if(alarmDelay>0) //alarmDelay decremented
alarmDelay--;
if(armDelay>0) //armDelay decremented
armDelay--;
if(callTime>0) //callTime decremented
callTime--;
if(hornCycle==0) //if hornCycle==0, horn inverted and hornCycle
reset to 3
horn=~horn;
hornCycle=3;
hornCycle--; //hornCycle decremented
//PORTC.3=~PORTC.3; //led
void main(void)
// Input/Output Ports initialization
// Port A initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out
Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0
State0=0
PORTA=0x00;
DDRA=0xFF;
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In In Func1=In
Func0=In
// State7=P State6=T State5=P State4=P State3=P State2=P State1=P
State0=P
PORTB=0xBF;
DDRB=0x00;
// Port C initialization
Func1=Out Func0=Out
State0=0
PORTC=0x00;
DDRC=0xFF;
// Port D initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=In Func2=In Func1=In
Func0=In
// State7=1 State6=1 State5=1 State4=1 State3=P State2=P State1=P
State0=P
PORTD=0xFF;
DDRD=0xF0;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: 7,813 kHz
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x05;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: 125,000 kHz
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: On
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x03;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: On
// INT0 Mode: Falling Edge
// INT1: On
// INT1 Mode: Falling Edge
// INT2: On
// INT2 Mode: Falling Edge
GICR|=0xE0;
MCUCR=0x0A;
MCUCSR=0x00;
GIFR=0xE0;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x05;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
// Analog Comparator Output: Off
ACSR=0x80;
SFIOR=0x00;
// LCD module initialization
lcd_init(16);
// Global enable interrupts
#asm("sei")
while (1) //main loop: waiting for correct,
checking for "arming", and monitoring "POWER"
keypad();
IGNITION=1; //ignition enabled
if(POWER==1) //when ignition power is turned on,
noAutoArm is reset (with debounce)
delay_ms(1000);
if(POWER==1)
noAutoArm=0;
if(correct==1||arming==1||
(settingsEntry==0&&noAutoArm==0&&autoArm==1&&POWER==0))
//if correct code fed, arming==1
already, or auto arming triggered
correct=0;
arming=1;
IGNITION=0;
lcd_clear();
armDelay=setArmDelay;
while(1) //loop: arming, with
delay
keypad();
itoa(armDelay,intToChar);
lcd_gotoxy(0,0);
lcd_putsf("arming... [");
lcd_putsf("] ");
lcd_gotoxy(0,1);
lcd_putsf(" [");
lcd_gotoxy(15,1);
lcd_putsf("]");
if(armDelay==0||armed==1) //if armDelay
time-out or armed==1 already
armed=1;
lcd_clear();
lcd_putsf("armed");
delay_ms(2000);
lcd_gotoxy(0,0);
while(1) // loop:
armed, waiting for sensor trigger or correctCode
keypad();
if(SENSOR==0||POWER==1||
triggered==1) //if SENSOR or POWER signal fed
or triggered==1 already
triggered=1;
lcd_gotoxy(0,1);
alarmDelay=setAlarmDelay;
while(1) //loop: triggered,
alarm being activated, with delay
keypad();
lcd_gotoxy(0,0);
lcd_putsf("alarm ");
itoa(alarmDelay,intToChar);
lcd_gotoxy(6,0);
lcd_putsf(" ");
if(alarmDelay==0||
alarm==1) //if alarm delay time-out or alarm==1
lcd_gotoxy(5,0);
lcd_putsf(" ");
alarm=1;
callTime=4; //CALL
signal activated
CALL=1;
while(1) //loop:
alarm activated
keypad();
BLINKERS=1;
HORN=horn;
if(callTime==0)
CALL=0;
if(correct==1) //if correct code fed, disarmed
break;
if(correct==1)
break;
if(correct==1)
break;
if(correct==1)
noAutoArm=1;
BLINKERS=0;
HORN=0;
CALL=0;
correct=0;
alarm=0;
triggered=0;
armed=0;
arming=0;
enterCode=0;
lcd_clear();
lcd_putsf("disarmed");
delay_ms(2000);
break;
well,
delay.
time.
analyze,
extremely
grateful =)
decremented
microcontrollers,
I'm
#include <mega16.h>
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
#include <delay.h>
#include <lcd.h>
#asm
#endasm
// global variables
this table
this table
autoArm
entering requested
of settings entry
settingsCodeQuery
POWER==1. if 1,
until reset
settings
calculated (n-t)
pointer p
for(c=0;c<4;c++)
code[c]='A';
p=0;
lcd_gotoxy(11,1);
lcd_putsf(" ");
void keypad()
lcd_gotoxy(0,0);
enterCode=1;
lcd_gotoxy(11,1);
code[p]=key;
key='A';
lcd_gotoxy(p+11,1);
else //otherwise
'*' is displayed
lcd_putchar('*');
delay_ms(200);
p++;
key='A';
keypad)
if(settings==0)
key=1;
settings=0;
lcd_clear();
lcd_putsf("]");
lcd_gotoxy(10,1);
lcd_putsf("[ ]");
okKey=1;
if(settings==0)
key=4;
settings=0;
lcd_gotoxy(0,0);
okKey=4;
key=7;
cancel=1;
cancel=0;
okKey=0;
settings=0;
settingsEntry=0;
enterCode=0;
nollaus();
if(code[p]=='A')
p--;
lcd_gotoxy(p+11,1);
lcd_putsf(" ");
code[p]='A';
lcd_gotoxy(p+11,1);
if(PIND.3==0) //
if(settings==0)
key=2;
settings=0;
lcd_clear();
lcd_putsf("]");
lcd_gotoxy(10,1);
lcd_putsf("[ ]");
okKey=2;
key=5;
key=8;
key=0;
if(PINB.2==0) //
if(settings==0)
key=3;
setting
settings=0;
lcd_gotoxy(0,0);
okKey=3;
key=6;
key=9;
t=0;
settingsEntry=1;
lcd_gotoxy(0,0);
query
keypad();
if(cancel==1) //if
cancel=0;
settingsEntry=0;
break;
if(correct==1) //if
mode
correct=0;
settings=1;
lcd_clear();
delay_ms(2000);
lcd_clear();
break;
denied
correctCode
arming==0)
lcd_clear();
else
lcd_gotoxy(0,1);
delay_ms(2000);
nollaus();
break;
if(t==3) //if all 4
nollaus();
correct=1;
break;
t++;
requested
if(code[3]!='A')
for(t=0;t<4;t++)
newCode[t]=code[t];
lcd_gotoxy(0,0);
nollaus();
okKey=5;
while(1)
if(code[t]!
lcd_clear();
lcd_putsf("mismatch
nollaus();
delay_ms(2000);
okKey=0;
settingsEntry=0;
break;
nollaus();
for(t=0;t<4;t++)
lcd_clear();
nollaus();
delay_ms(2000);
okKey=0;
settingsEntry=0;
break;
t++; //t
if(code[3]=='A') //
n=2; //
if(code[2]=='A') //
n=1; //
if(code[1]=='A') //
n=0; //
armDelay=0;
r=1;
r=10*r;
lcd_gotoxy(0,0);
lcd_putsf("] ");
okKey=0;
settingsEntry=0;
delay_ms(2000);
nollaus();
if(code[3]=='A') //
n=2; //
if(code[2]=='A') //
n=1; //
if(code[1]=='A') //
n=0; //
alarmDelay=0;
r=1;
r=10*r;
lcd_gotoxy(0,0);
lcd_putsf("] ");
okKey=0;
settingsEntry=0;
delay_ms(2000);
nollaus();
autoArm=code[0];
noAutoArm=1;
lcd_clear();
if(autoArm==0)
if(autoArm==1)
enabled");
okKey=0;
settingsEntry=0;
delay_ms(2000);
nollaus();
lcd_gotoxy(0,1);
lcd_gotoxy(0,0);
mode
enterCode=0;
lcd_gotoxy(0,0);
multiplexed
PORTD.4=1;
PORTD.5=1;
PORTD.6=1;
PORTD.7=1;
if(m==4)
PORTD.4=0;
if(m==5)
PORTD.5=0;
if(m==6)
PORTD.6=0;
if(m==7)
PORTD.7=0;
m++;
if(m==8)
m=4;
alarmDelay--;
armDelay--;
callTime--;
reset to 3
horn=~horn;
hornCycle=3;
void main(void)
Func1=Out Func0=Out
State0=0
PORTA=0x00;
DDRA=0xFF;
Func0=In
State0=P
PORTB=0xBF;
DDRB=0x00;
Func1=Out Func0=Out
State0=0
PORTC=0x00;
DDRC=0xFF;
Func0=In
State0=P
PORTD=0xFF;
DDRD=0xF0;
TCCR0=0x05;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x03;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: On
// INT1: On
// INT2: On
GICR|=0xE0;
MCUCR=0x0A;
MCUCSR=0x00;
GIFR=0xE0;
TIMSK=0x05;
ACSR=0x80;
SFIOR=0x00;
lcd_init(16);
#asm("sei")
keypad();
delay_ms(1000);
if(POWER==1)
noAutoArm=0;
correct=0;
arming=1;
IGNITION=0;
lcd_clear();
delay
keypad();
lcd_gotoxy(0,0);
lcd_putsf("] ");
lcd_gotoxy(0,1);
lcd_putsf(" [");
lcd_gotoxy(15,1);
lcd_putsf("]");
armed=1;
lcd_clear();
lcd_putsf("armed");
delay_ms(2000);
lcd_gotoxy(0,0);
while(1) // loop:
keypad();
triggered=1;
lcd_gotoxy(0,1);
keypad();
lcd_gotoxy(0,0);
lcd_gotoxy(6,0);
lcd_putsf(" ");
if(alarmDelay==0||
lcd_gotoxy(5,0);
lcd_putsf(" ");
alarm=1;
callTime=4; //CALL
signal activated
CALL=1;
while(1) //loop:
alarm activated
keypad();
BLINKERS=1;
HORN=horn;
if(callTime==0)
CALL=0;
break;
if(correct==1)
break;
if(correct==1)
break;
if(correct==1)
noAutoArm=1;
BLINKERS=0;
HORN=0;
CALL=0;
correct=0;
alarm=0;
triggered=0;
armed=0;
arming=0;
enterCode=0;
lcd_clear();
delay_ms(2000);
break;
