Why does a meter short out when measuring VCC and VDD at the same time
Discussion in 'General Electronics Discussion' started by Simmon, Feb 13, 2014.
  1. Simmon
    Simmon
    76
    Jan 30, 2014
    Why does a plug in bench DVM meter short out when measuring VCC and VDD at the same time?
    VCC is -30volts and VDD is -30 volts
    The Bench DVM meter shorts out the burns the circuit board, but why?
    How do you prevent this from happening?
  2. Simmon
    Simmon
    76
    Jan 30, 2014
    Corrected sorry
    VCC is +30volts and VDD is -30 volts
  3. Harald Kapp
    11,444
    2,629
    Not necessarily so.
    - Can you provide a sketch of your measurementg setup?
    - To what range was the meter set (voltage, current, magnitude)?
  4. Simmon
    Simmon
    76
    Jan 30, 2014
    Voltage
    It's a Bench DVM meter that plugs into the wall
    Can this DVM meter being plug into the wall cause it to be grounded? causing a short from VCC +30 volts to -30 VDD ?
    I had my red dvm meter probe on VCC +30 volts and my black meter probe on VCC -30 and it shorted out the power supply diodes and fried the board
    But why?
  5. davenn
    davenn Moderator
    13,812
    1,945
    as asked show us your setup
    some sharp and well lit pics would be great
  6. Harald Kapp
    11,444
    2,629
    How is your measurement set up?´How is the meter connected to the different voltages? How are the different voltage sources connected between each other?
    The reason for my questions:
    When you meter is set up for voltage measurement, it should not short the two voltages. Sounds like you put the meter into current measurement mode.
    Another possibility is if there is a ground loop somewhere in your circuit, e.g. caused by a grounded meter. This should not happen, but who knows. Check the manual, for any note reading ground connection of the meter. Use an Ohmmeter to verify the inputs of your dvm are not grounded.
  7. Simmon
    Simmon
    76
    Jan 30, 2014
    How can I do a test like this? grounded to what? and where?
    Turn the DVM meter ON , to voltage mode and measure the ohms from the Red meter probe to what ground?
    AC step down transformer , that it's secondary is floating , goes to rectified diodes, caps but has a Plus + 30 vdc and -30 vdc output
    How can a ground loop be caused by a grounded meter?
  8. Harald Kapp
    11,444
    2,629
    Show us a diagram, please.
    Maybe a silly question to ask, but the test leads are put into the correct sockets of the meter? Most meters I know have separate connectors for current and voltage. Setting the meter to voltage mode doesn't help if the lead is set into the current connector.
  9. Simmon
    Simmon
    76
    Jan 30, 2014
    NO power turns on
    Do I disconnect the plug and measure the ohms from the plug ground to the red and black probes?
    But where is my reference? is it the AC plug ground?
    Yes , set to voltage and pluged into the voltage sockets
  10. Harald Kapp
    11,444
    2,629
    Measure the resistance between the dvm's inputs and the connectors of the two voltage sources. No other reference is required.
  11. davenn
    davenn Moderator
    13,812
    1,945
    Simmon
    read carefully
    this is your last chance if you dont answer this before saying anything else
    I will lock the thread ... you have been asked multiple times
    show us your setup ... either drawings and or photos
  12. tryppyr
    tryppyr
    228
    Oct 22, 2013
    Probably an impertinent question... but what brand of meter is it? Wouldn't happen to have come from Harbor Freight, would it?
