Steve said:
Duck tape and duct tape are TWO DIFFERENT THINGS!!!!
Duck tape is made from cloth and is a REALLY bad choice for using on
ducts. It was designed originally to repair tarps and withstand the
weather.
Duct tape is made from metal foil and is designed for use on metal
ductwork.
Wrong. Again.
The original DUCT tape had and still has NO metal foil.
http://tinyurl.com/ywrzu5
Metal tape with adhesive is known as "flashing tape", used to seal the
edges of roofs to prevent the ingress of moisture under the edge of
roofing material or between walls that are built hard up against each other.
Flashing used to be done with lead foil sealed/glued with pitch, now it
is done with adhesive metal [usually aluminium] tape, hence "flashing tape".
In Australia, generic "duct tape" is essentially like a very wide
electrical tape: a stretchy PVC backing with glue on it, usually about 2
inches wide.
This tape that's cloth backed in plastic with an easy release adhesive
sounds more like "gaffer tape", which is used extensively in the
entertainment industry to hold electrical cables in place and for
slapdash on-the-spot repairs.
A "gaffer" is an on-set electrician used during the making of a movie or
in-house electrician for a theatre, hence "gaffer tape".
