george2525
- Jan 30, 2015
- 170
- Joined
- Jan 30, 2015
- Messages
- 170
Hi
I have been designing a sample and hold circuit and the portion im confised about is shown below. Im not using multisim, its just a drawing tool.
The tl071 is a comparator that I havnt bothered to draw properly that outputs around +/- 4.5V depending on its input
Q1 switches on and off based on this and the cap charges to the "cap charge voltage" which is between 0.1V (shown) and 3.1V at its max.
U2A is just a high impedence buffer to trap the charge.
Q1 is a Jfet 2N3819 (standard)
the switch -Q1 is turned on and off very fast to store whatever voltage is at the drain on the cap. so the sample command causes the comparator to go to 4.5V and then back down to -4.5 very fast.
OK so - when the 10 Mohm resistor WAS NOT there the circuit didnt work - the cap discharged fast, sometimes going up and down a bit - it was pretty useless.
I decided to mess about and add various resistances to the gate. low and behold when I did this it started to work! the bigger the resistance, the more accurate the capacitor charge (as R1 was increased the cap voltage was closer to 0.1V in this example)
I cannot fathom why this helped. I thought the Jfet gate had massive resistance anyway so what use is adding a bit extra? Im thinking something to do with the op amp output resistance or something in its internal circuitry?
Anyway it works nicely as shown but it realy bothers me that I dont understand what the R1 has achaived.
Can anyone help here?
