Categories
Platforms
Content
The monitor have both connect vga and rca input jack.Hi, does your monitor have video-in?.
DVR’s, TV’s etc do (mostly).
You possibly need a VGA adapter. What monitor is it?.
Martin
The camera set for ntsc Not pal.There are two different types.
PAL and NTSC.
Depends which country you are in as to most common type.
You need to supply more detail on the camera, monitor dvr what plugs you are using etc. etc.
mrel
yes monitor have yellow input when using yellow video input no picture from camera ,but when connect camera to DVR get picture.Have you got three RCA’s, white, red and yellow?. Yellow being the video inplut.
If not, you will require a vga converter.
Martin
