I suspect it is though...
Can you post some urls that support your position?
Ed
There are several that will support this. Try:
http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=guide_bpw2_c09_01
or:
http://www.powerstream.com/BatteryFAQ.html
Note particularly the comments uder the NiCd type.
Historically, this is why NiCd batteries ar still favoured, in 'traction'
type applications (together with lead acid). There are new generation NiMh
batteries that are starting to move into this market (look at cordless
drills, where some makes are now moving to NiMh), and these have
comparable or even slightly better maximum currents. There ae two 'parts'
to this, both the relatively low internal resistance (which is what
matters in the mobile phone application), and also relatively good
performance from the cell as it's temperature rises. This is why
lead-acid, or NiCd batteries are being used in current electric car
designs, and NiCd batteries for electric flight.
NiMh, give higher total power capacities, but it their high capacity
versions, have higher self-disharge rates.
As with all such things, there is a problem with 'generalisations'. High
capacity batteries, usually have less actual electrolyte, thinner
electrodes, and higher internal resistances. If one of these is
substituted into an application designed for a battery supporting high
currents, the result can very easily be cell rupture. Most manufacturers
do both types in a specific chemistry. NiCd cells designd for traction
use, are different 'beasties', from the sort commonly sold.
I suspect the real problem, is in cell voltage. The original poster,
refers to the battery as 1.5v nominal, and then points out that a
significant percentage of it's 'life', will be spent with a working
voltage comparable to the NiCd cell. The 1.5v nominal voltage and
discharge curve being talked about, sounds like that for a zinc-carbon
battery, not the alkaline cell. For medium loads, this maintains a voltage
over 1.25v much further into the design life, than for a zinc-carbon, or
NiCd cell. I suspect the stapler, is one of an unfortunately 'common'
class of devices, which only uses the first perhaps 40% to 50% of the
cells capacity, and requires the higher voltage available here, which is
not offered by the NiCd cell...
yes they are used in cordless screw drivers and such.
Best Wishes
