W
Watson A.Name - \Watt Sun, the Dark Remover\
I built up a FET version of the phase shift oscillator on the right of
http://ourworld.compuserve.com/homepages/Bill_Bowden/page8.htm#func.gif
I used a 1.5k source resistor bypassed by a 1000 uF cap. The drain load
resistor is 3.9k, and the supply voltage is 9VDC. The 3 caps are 10 uF,
and the three resistors to common are 150k each. The FET is a MPF102.
The drain voltage is about half the supply voltage.
When I power it up, I get the damped sine wave, I can see it on the DVM.
The voltage gain for a PSO has to be at least 29 to oscillate, so
apparently I don't have enough V gain to make up for the losses in the
network.
How do I get more V gain out of the single FET? The source is fully
bypassed. Thanks.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
network.
bypassed. Thanks.
