D
daestrom
Energy said:So using a radius of 38 meters, we have a total area of 4,536 square
meters that we've devoted to energy extraction.
A 14 m/s breeze has an energy density of 1631 watts per square meter.
So we have a total potential of 7.4 MW of energy. Taking 59% of that is
4.37 MW. And what is our GE generator doing? It's extracting 1.5 MW,
or 34% of the realistic maximum energy, while 66% is sailing right
through those long skinny blades.
Pretty neat trick to not do what I did - which is to consider the total
swept blade area. Like I said, I've just proved that 2/3 of the
extractable energy is sailing right between these skinny blades.
And I proved that it is *more* than just the blade face area that is
extracting energy. What's your point?
You think more area will extract more energy? Perhaps, but more area
will also increase the losses so the net output is not improved. And
that's why thousands of engineers around the world that design these
things for a living have compromised at three blades and not a larger
number. Guess they didn't have your 'insight' to revolutionize the
industry.
Even to a non-engineer, it's obvious that a lot of wind *will* sail
right between those blades. Why isin't that obvious to you?
You've misunderstood my position. I'm saying that adding more area will
not increase the power output very much more than you already get with
three blades. That's all I'm saying.
You seem to think that putting more blades on will somehow increase the
power output by a significant margin, but all you have is 'seat of the
pants' idea, no facts to back it up.
Wrong. Wind speed is wind speed. Differential pressure (when expressed
in terms of square inches or meters) is of the same scale, whether we're
talking about a huge blade or a house fan.
Pressure is not measured in square inches.
And the differential pressure across the unit is a big deal. Study the
Betz limit derivation and you'll find it right in the middle of
everything. Home fans accelerate just the air column through the fan
and as soon as it exits the fan a large fraction spins off in eddies and
recirculates. This is because the fan not only increases the dynamic
pressure (caused by the velocity of the air), but also the static pressure.
Commercial ventilation fans used in ductwork develop even more dP across
them. Have to in order to get air to flow through the duct-work.
Centrifugal pumps are a similar machine and similar design tradeoffs.
You want a lot of flow at low head, go with axial flow (wind-turbine or
fan). You want a high head but not so much flow, go with a volute
design (centrifugal blower style). You want even more head, go
multi-stage (jet-engine compressor).
Why is it so hard for you to understand that wind turbines are very low
head, high flow devices and that is a major dictator of their design?
A propeller blade (and I suppose a wind-generator blade) will have a
cross-section that looks like the profile of a wing (camber) for only
one reason: To improve the lift-to-drag ratio. A flat profile blade
will have a similar lift-to-alpha ratio as a cambered profile (alpha =
angle of attack).
Yes, the camber improves the lift-to-drag ratio by *increasing* lift.
Not reducing drag. If a flat blade had the same lift as a cambered one
for a given angle of attack, then the Wright brothers and all the
aeronautical engineers since then have wasted a lot of time making
cambered wing designs.
BZZZT. I'm sorry, you're wrong. But thank you for trying.
Yes, I know that.
So you just stated that the blades would be pull forward just for sake
of arguing.
I'm responding to the argument that a wind blade is shaped like the wing
of a plane (specifically - a glider).
Which they are, except they have a twist along their length to account
for the change in 'apparent wind' angle caused by the faster tangential
speed as you move further from the axis.
My point is that aircraft wings are designed for cruise flight, where
the angle of attack is very small - if not zero.
A wind blade will not have such a small angle of attack. Quite the
opposite.
Again you don't seem to understand how the speed of rotation and the
wind speed combine to have the air approaching the blade nearly head on,
almost the same angle as an air plane wing.
Look at a blade up close and you'll see that the wind doesn't 'push' on
the curved side, that would make the thing rotate in the other
direction. It blows against the 'flat' side (what would be considered
the bottom of an airplane wing) at a very shallow angle and flows over
the back, curved side (top of an airplane wing) in a smooth (ideally
laminar) layer.
daestrom
