Why are there no low pin count FPGAs?
M
M. Noone
Hi - I was considering th possibility of replacing a microcontroller
(Atmel atmega168) with an FPGA. I realized that an FPGA would be much
better suited for the application. The only FPGA work I've ever done
was with the popular Xilinx Spartan3 board. I started looking for a
suitable replacement chip - and I quickly ran into an issue: all FPGAs
are huge! A search at digi-key of 'FPGA TQFP' found chips with 100 pins
and more - nothing less. Such a large chip won't even physically fit on
this board. So - can anybody explain what I'm missing here? Is it that
FPGAs are normally designed to run with external memory, so they need a
large bus for that? I am aware of the smaller BGA FPGAs, but I don't
have the equipment to produce FPGA boards.
-Mike
John Larkin
-Mike
The smaller parts are called CPLD's. They start at 20 pins or so.
John
T
Terry Given
John
Yeah, but what if you want lots of logic and very few IO pins?
Cheers
Terry
T
Tilmann Reh
John said:
[FPGAs in smaller packages]
But there also are no "larger" CPLDs in small packages...
I would have needed them several times. For example, the smallest
package for the Xilinx 95144XL is the TQFP100 (with 0.5mm pitch :-( ) -
I would like that chip in a 44-pin package for applications with less I/O.
The dilemma is, there simply are no such larger programmable logic
devices (no matter if CPLD or FPGA) in small packages (from neither
maker). Seems there's not much market to them, or they didn't recognize
there is one...
L
Leon
Most customers want lots of I/O, the market for smaller packages would
be limited and they would be very expensive.
Leon
S
Slurp
-Mike
Well your problem here is lots of logic. Lots of logic = large silicon area.
Large silicon area = large package. Manufacturers are not going to produce a
18 x 18mm package - or larger - with 20 pins!
It is just uneconomic to do so.
If you have a minimal logic requirement go for a CPLD, packages typically
will have fewer pins.
Slurp
Consider this, is it easier to not use a pin rather than trying to add a pin
for a customer that needs it?
FPGA capabilities is a compromise. Otherwise people would just had an asic
made.
So it makes more business sense to have one chip sold to those that needs many
pins and those that doesn't need them. Split the production, and cost rises.
The only argument I can see is that of not useing bga packaging. And too thin
pitch that is just unsolderable by any normal means.
And one could always make a small breakoutboard vq100->dil14 etc.. if one wants
that.
T
Tim Wescott
there is one...
Or the chips are huge and _need_ those big packages.
Although I'm always willing to believe in vendor stupidity.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Posting from Google? See http://cfaj.freeshell.org/google/
"Applied Control Theory for Embedded Systems" came out in April.
See details at http://www.wescottdesign.com/actfes/actfes.html
R
Rich Grise
there is one...
If you're just talking about board real estate, then with the little teeny
tiny pins on those little flat packages, the whole thing is about the size
of a postage stamp. Just lay out your board with the .5mm traces or
whatever, and strap the unused pins to Vcc or gnd. IOW, figure out the
mounting, and just ignore the pins you don't need. Then the only problem
is the PCB layout.
Good Luck!
Rich
John Larkin
That's probably less common than the reverse, running out of pins. My
designs seem more often constrained by pin count than by internal
resources, unless we bite the bullet and go BGA.
John
Q
qrk
-Mike
Virtex 2 has small BGA packages with 0.8mm pin pitch. There are web
sites discussing how to solder BGA packages at home using a toaster
oven. Many designs require large amounts of I/O. Thus, the FPGA
manufacturers cater to the average. Plus, a large percentage of pins
are power/ground.
M
M. Noone
John
That seems to be what I was missing. As discussed in this topic by
others though - these seem to be much more limited in features.
So that brings me to a new question: Are there any FPGA/CPLD like
devices that have built in ADCs? That is the only feature of importance
I'd be losing by switching over to a CPLD from a microcontroller. Does
such a thing exist? The board that this is intended for is very small
(1.5x4.725cm) and very full so having to add an external ADC would be
difficult.
-Mike
John Larkin
difficult.
You might check Actel. You can also make a single-slope or delta-sigma
ADC using mostly internal FPGA resources, if accuracy needs are
moderate. There are also tiny ADCs around, SOT-23 and smaller.
John
D
David L. Jones
-Mike
You are right, all FPGA's have HUGE pin counts. The higher the logic
density the greater the pin count. It is one of my pet hates.
For one of our applications we needed one of the top of the line FPGA's
for the density, but only needed about a dozen I/O pins. So we were
forced to use a *960* pin BGA - INSANE!
We asked the top three FPGA manufacturers to explain this, and their
general response was that it doesn't really cost them any more to put
on all the extra I/O, and there is most demand for the high pin count,
so they have simply abandoned the low pin count market for good. If I
recall correctly, Actel were the only ones who put their hand on their
heart and said they would continue to support the "low-ish" pin count
QFP packages.
Dave :)
John Larkin
Wow, what sort of application needs all those gates but only a dozen
i/o's?
John
John Larkin
Counters.
Cool. If we use SPI to manage and read out the counters, that leaves 9
count-input pins. So you can have nine, say, 10,000 bit counters.
John
D
David L. Jones
i/o's?
John
It was a dual path redundant E1 data stream over 155Mbit ATM fibre. So
basically, just 6 serial buses in and out - a dozen pins total plus a
few misc.
The commercial E1 and ATM VHDL cores we had took up lots of resources,
so we needed the biggest device Altera had at the time, and of course
that only came in a 960pin BGA :-(
Makes quick prototyping a ridiculous exercise!
Dave :)
M
M.Randelzhofer
-Mike
We produce small FPGA and CPLD boards in a PAL compatible 24pin DIL pinout.
The FPGA board also incorporates 512kx8 SRAM and 8Mx1 FLASH.
It's well suited for education purposes and serial I/O.
see:
http://shop.trenz-electronic.de/catalog/product_info.php?products_id=81
However lots of customers asks for more I/O's...
So the next ones have more I/O's, for $++.
MIKE
PS: ROHS forces us to sell out our PB contaminated modules, so its prices
are very userfiendly...
www.oho-elektronik.de
OHO-Elektronik
Michael Randelzhofer
FPGA und CPLD Mini Module
Klein aber oho !
M
Mike Harrison
see:
A 40 pin DIL option would be nice, also maybe a basic lower-cost version without flash, sram and
level-shifters.
