facetheash
- Oct 12, 2011
- 3
- Joined
- Oct 12, 2011
- Messages
- 3
when I reffered to a datasheet a broadcom 8 port switch.... The Pins PLL_REFCLKp and PLL_REFCLKn are connected to a 100 ohm resistance. when I referred the data sheet it says "the input has internal AC coupling capacitors which requires a 100 ohm differential termination on the board and requires a DC biasing".
Could someone explain this point
