So lightning enters the building on AC electric (black hot
wire) seeking earth ground. It arrives at those three MOVs
(called a plug-in surge protector) adjacent to a computer.
Now where does lightning go. Through an MOV to a spike in the
floor? That spike is not well connected to earth. Instead,
those MOVs shunt (distribute) that lightning strike to all AC
electric wires. More wires to seek earth ground,
destructively, through the adjacent computer.
Some possible paths from computer to earth ground - phone
line through modem; serial port cable where it drapes over
baseboard heat; or out via network card. These are all
potentially computer destructive paths because 1) a superior
and single point earth ground was not utilized at the service
entrance ('whole house' protector) and 2) because the spike in
a floor only labeled as ground does not make a conductive
connection to earth.
Chris Lewis's assumptions might be valid for normal mode
protection. And that is what Chris Lewis has assumed all
surges are:
... when there are large voltage differences between the
conductors entering a device.
But just like the plug-in protector manufacturers, Chris
forgets that typically destructive surges are common mode.
That means no voltage difference between wires while a
destructive voltage difference exists between ALL wires and
earth ground.
Therefore the 'spike labeled ground' accomplishes nothing
and leaves electronics exposed to destructive transients.
Aircraft grounding is completely different and more
complex. If one does not even understand normal and
longitudinal transients, then one has no right trying to
complicate the concepts by discussing aircraft. We are
discussing terrestrial structures and destructive transients.
Any discussion about aircraft only confuses the issue made
complicated enough when Chris does not even understand the
transient that is typically destructive. Instead he assumes a
transient is only a voltage between two wires. There are
other and typically more destructive types of transients. And
no place are we discussing helicopters.
