W
w_tom
And again we have this misconception that a 'service entrance' and a
'point of use' protectors are protection. Again, protectors and
protection are two different components in a protection 'system'.
Again, protection is that single point earth ground. Protectors are
only electrical switches or connections to that single point ground.
A protector without that single point earth ground is doing nothing
effective.
The CATV line is as easy to protect as all other incoming utility
wires. It must first make a connection to single point earth ground -
the protection - before entering the building. Newly revitalized
cable companies are now teaching their employees this 60+ year old
technology. Technology that long understood and that repeatedly
proven. And yet still, here in the 21st Century, we still have people
'assuming' a protector is protection. A protector is only as
effective as its earth ground. How does the incoming cable get
protected? Throw away the protector and connect that incoming cable
direct - hardwired - to single point earth ground. No earth ground
means no effective protection.
Why might the TV be damaged on its cable connection? If cable was
properly earthed, then incoming transient is on some other utility.
One typical incoming source is the AC electric (especially if
appliance is connected to an adjacent plug-in protector). Incoming on
AC electric, through TV, and outgoing to earth ground via cable.
First everything in an electrical path from cloud to ground conducts
the transient. Only then does one device in that path fail - often a
component on TV's cable connection. Many then assume the surge came
in on cable when, in reality, surge was incoming on AC electric and
outgoing on cable connection.
effective.
