K
krw
*CLOCK* radio!
Thought you might be raising chickens, too. ;-)
*CLOCK* radio!
krw said:78xx <> switch mode DC-DC.
95% efficiency is a bit optimistic for the real world. 85%, perhaps.
I still don't want to increase my power bill by even 10%, though it's
better than 10x.
Most power supplies are more or less the same thing. That said, there
is still no advantage to DC distribution and a *LOT* of
disadvantages.
You still haven't identified *ONE* reason to go through this crap.
At last someone who gets it. There have been others critical of
a separate DC power system and they have good point about why
you should not reinvent the wheel. Inverter technology has come
a long way in recent years and what would you think of a central
high capacity inverter coming off your battery bank. Many of the
backup generator systems I've installed over the years have not
been designed to take care of the whole electrical load of a
home or business but to supply power to the essentials through
a transfer switch and sub-panel. The same thing can be done with
an inverter system. By the way, Tesla is more of a hero to me
than Edison. I think Edison just had a better publicity machine.
TDD
Nor was I trying to. I've pointed out the faults all along, I was only
commenting on some of the points.
I'm not the OP.
krw said:No, Dufus, it is you who doesn't "get it". What is possible is
irrelevant, if the dream is worse than what is.
Yes, all telling you that your idea is stupid.
I agree. Everyone agrees that your idea is stupid.
You have to have some thoughts before they can be provoking. Try it.
You are what you are. I've simply told you what you are. Grow up and
deal with it.
Something that should be immediately obvious to anyone posting in a
science/engineering group.
Ah, so you're testing us? You're not just stupid, but a stupid liar.
Do keep the really stupid ones to yourself.
It wasn't my idea to start with you idiot, it was
a discussion about possibilities. I'm so glad that
a world leading expert such as yourself would chime
in and share your dearth of knowledge. *snicker*
Tom said:DC Power transmission lines are used to rid the line of skin effect
and allow the entire cross section of the conductor to carry current.
They are as yet only practical for long haul point to point
circuits.
circuits.
That's what I read. My only experience with high voltage power
transmission has been installing buried conduit, setting transformers,
making connections and splices on 15kv coaxial underground cable.
Of course there was all of the other wiring on the low voltage side
of the transformer including the facilities wiring. What I find
fascinating about the long haul high voltage DC power transmission
systems has to do with the changes in technology over the years to
handle the conversion of AC to DC then back again. The early mercury arc
valve systems have got to be a sight to behold. I can imagine a mad
scientist wearing super thick lensed glasses cackling in the background.
TDD
The said:At last someone who gets it. There have been others critical of
windcrest said:A more practical solution would be special J boxes that have the
transformers in them and are sensitive to loads being plugged/
unplugged and cut off power to the primary when not in use. Everyone
hates wall warts, they draw a little current even when not in use.
Your electrician would then install these low voltage outlets easily
throughout the house. The important thing is that they be able to
detect "no load" and cut off the primary, and sense an item being
plugged in or turned on and re-connect the transformer primary. Your
whole house DC distribution idea would not be able to do this because
it has to be "ready" globally with no local outlet control sensors.
George said:You just reinvented the wheel. Battery storage with an inverter (or
inverter/charger if a generator is used) to supply normal
voltage/frequency AC is a pretty common method for off grid installations.
Part of the pumping system was a Mercury vapour pump! Can't remember how
they worked it's too long ago. There probably were traps of some sort or
other, otherwise we would have been forever topping up the Mercury, which
we weren't. However, back in those days I don't think anyone was too
concerned about it. I was never really involved in the maintenance of the
system anyway as my job was operational and looking after the RF side of
things.
Stuart
There is no reason that could not be designed into wall-warts.
I've never measured the quiescent primary current draw of old
style wall-warts verses the newer tiny switcher wall-warts, I'm
sure someone has done so. I think your idea is great for office
cubicles because it could be built in during manufacturing and
would help lead to a less cluttered work space, at least for
some people.
TDD
Even a 5Kw 6 phase converter was a sight to see- looked like an octopusThe Daring Dufas said:That's what I read. My only experience with high voltage power
fascinating about the long haul high voltage DC power transmission systems
has to do with the changes in technology over the years to handle the
TDD
Don said:Even a 5Kw 6 phase converter was a sight to see- looked like an octopus
with glowing arms and a bright spot dancing on a dish of mercury.
Seriously the advantages of DC transmission has relatively little to do
with skin effect as conductors are typically ACSR with aluminum on the
outside and steel inside- and, at these voltages are grouped in
bundles. The size of the conductor has more to do with mechanical than
electrical properties.
DC transmission at high voltages is economical for long lines where the
reduced cost of the line exceeds the added cost of the terminal
equipment. There are also some other technical advantages . This
breakeven point is at a much shorter distance for underground or
underwater cable. DC back to back terminals are often used where
frequency differences (e.g. in Japan with both 50 and 60 Hz systems) or
stability concerns arise. They do have the disadvantage that reasonable
and economic circuit breakers for DC don't exist and this means that
the system is essentially point to point rather than through an
interconnected grid. In addition, conversion from one voltage level to
the next is bloody expensive, awkward and inefficient compared to the
use of AC transformers.
At low voltages, even for relatively short distances, DC is not a viable
option.
Seriously the advantages of DC transmission has relatively little to do with
skin effect as conductors are typically ACSR with aluminum on the outside
and steel inside- and, at these voltages are grouped in bundles. The size
of the conductor has more to do with mechanical than electrical properties.
reduced cost of the line exceeds the added cost of the terminal equipment.
There are also some other technical advantages . This breakeven point is at
a much shorter distance for underground or underwater cable. DC back to back
terminals are often used where frequency differences (e.g. in Japan with
both 50 and 60 Hz systems) or stability concerns arise. They do have the
disadvantage that reasonable and economic circuit breakers for DC don't
exist and this means that the system is essentially point to point rather
than through an interconnected grid. In addition, conversion from one
voltage level to the next is bloody expensive, awkward and inefficient
compared to the use of AC transformers.
option.
There may still be a few tucked away in buildings with really old DC
elevators, although there can't be many left now that haven't been
updated.
cheers
Jules
I do not think there have been DC elevators in the US since the late
Thirties.
