A 20 watt home fluorescent light, is allway brightest than a 20 watt
fluorescent light which is operate by 12 volt car battery dc to ac
converter.
Can any person know ?
Fluorescent lights are not like incandescent lamps. While the wattage in an
incandescent lamp can determine brightness, wattage determines power
consumption of the ballasts with fluorescent lamps. In fluorescent lights,
wattage has nothing to do with total light output.
Amperage, however, might. You are going to have better amps from house current
than from a DC battery running an AC converter.
It all depends on how well the ballast will allow the tube's electrodes to arc
across the gas inside, manipulating the electron orbit of atoms of mercury
vapor in the tube to generate UV light, which excites the inner phosphor
coating on the glass which makes it fluoresce.
How well the ballast may work to do all this to generate the UV light depends
on its condition and the power quality. - Reinhart
