John Larkin
Noise across the audio spectrum of a small speaker. The speaker will be
some metres away from the signal generating part of the device. The noise
level must be controllable nearly upto the limit of the speaker.
I have just about come around to the idea of a 12 volt Zener diode driving
two LM741s followed by a LM368N to drive the speaker. The op-amps would
have a 12 volt unbalanced supply with the + inputs of the LM741s biassed to
6 volts. The parts are all available and cheap. I have the speaker. Would
this work in your view?
R
You can't really zener a 12-volt zener from a 12-volt supply.
And 741's are notoriously noisy themselves, which can cut both ways.
John
