This can be caused by two simple phenomena. The first is power supply
droop. I have had this happen on electronic devices before and it was cured by
slightly larger filter capacitors. The second is that some devices undergo
constriction effects in rapidly changing electrical or magnetic fields. The
whine from a television or monitor is due to magnetostrictive effect in the
transformer, and some ceramic capacitors are also known to do this, due to
voltage induced dimension changes. In other words, something similar to
piezoelectric effects.
Cheers!
Chip Shults
My robotics, space and CGI web page -
http://home.cfl.rr.com/aichip
