Which university produces good analog EEs?
Dang, I just knew you'd say that ...
For us board level guys the situation looks pretty dire.
Micropower bandgaps show up in really mundane areas of chip design
nowadays, such as POR. Really overkill, but because customers know it
can be done, they expect it to be done. If you reverse engineer Maxim
chips, you'll find a bandgap comparator circuit in the POR. Plenty of
patents on such circuits, but never litigated to my knowledge. They do
save power since the bandgap and comparator are folded into one
circuit.
One of the trickier micropower circuits are those in thermal shutdown.
That is where leakage can really kill you, so parasitics are required.
However, it isn't exactly rocket science.
BTW, I forgot to mention it, but UCLA has a fair amount of analog
design classes. Lastly, there is the Swiss Federal Institute of
Technology (or close to that). They have all sorts of papers on
dynamic biasing scheme, i.e. schemes to make micropower op amps slew
quickly by boosting tail current, etc.
Probably only the duds applied to your company ;-)
Eh, maybe they just wanted a trip to Silicon Valley. I was amazed at
the number of MIT grads that had logic design on their resumes, but
didn't know how to draw basic mos logic gates. It turns out they
studied computer architecture with silicon compilation to get to the
end product. That just doesn't fly on small mixed mode chips where the
logic is implemented in rather coarse mos technology.
JosephKK
Joerg [email protected] posted to
sci.electronics.design:
The HV switch? I think he went the white-knuckle route using a FET
stack. A ballast triode would probably have been the perfect fit.
Problem is, they don't make'em no more :-(
Ah but they do. High voltage (over 1000 V) vacuum tubes still
popular. I think Win even used a tube solution for a 10kV ramp
generator recently.
T
Tim Williams
generator recently.
That was the one.
Tim
Joerg
Ah but they do. ...
Who? There are some tube mfgs and probably the largest ones are Sovtek
and Svetlana but there ain't much in HV tubes there. It's all audio
because that is where the big bucks can be made.
... High voltage (over 1000 V) vacuum tubes still
generator recently.
IIRC he opted for a FET stack.
Joerg
circuit.
[/QUOTE]
Yes, on chips this is no problem but no company has marketed those
individually at a decent price. Meaning the sub-10uA references are
usually not very suitable for mass production because you can't have a
reference in there that costs more than all the rest of the board. So we
have to use tricks such as pulsing and storing.
One reason why POR/BOR circuits contain precise references is that the
chips they are on need it elsewhere as well. For example, a uC with an
ADC on board. The often touted "cheat reference" consisting of four
equal resistors hung onto the rail doesn't cut the mustard.
We didn't have much luck with UCLA so far. They didn't understand my
module specs and couldn't even solder. Had to let them go. Europe would
be an option but the immigration procedure is a real hassle. Plus there
will be an expensive international move required unless you catch them
right after their degree. Europe doesn't have such an extreme shortage
of analog guys because larger companies there are often foolish. Some of
them consider anyone over 40 a geezer that needs to be replaced by a
kid. The consequences are very visible, for example with NXP's web site.
R
RST Engineering \(jw\)
....and some really nice HF RF linear power amplifier devices.
Jim
Joerg
Ok, yeah, of course you can still get some of the really big tubes. But
those aren't practical and economical for a small HV circuit while the
old TV ballast triode might have been.
M
Michael A. Terrell
http://broadcast.rell.com/tubes.asp
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
JosephKK
Sovtek and Svetlana but there ain't much in HV tubes there. It's all
audio because that is where the big bucks can be made.
I am asking him.
POR really should reflect what it takes to make the chip fly, not
necessarily some arbitrary specification. That is, logic needs at
least a VT, the worse case of N or P. So generally a chip POR will
have a circuit that insures you at least have enough juice to turn on
your worse case fet. Once you trust the logic (well, at least under
static conditions), the next step is to insure the bandgap is awake,
generally an output something above a VTN. Throw in a timer and
hysteresis to make sure the supply rail hasn't sagged. Stuff like
that. Thus POR is process and temperature dependent. However, as you
probably know, that doesn't give the customer the warm and fuzzy
feeling. They want to see something nice and snappy that can be
verified with a DVM.
Oh yeah, the lack of soldering skills. That would require the student
to have actually built something. These younguns just know how to
program. You've seen the posts where a pic uP is the solutions to any
task, not a state machine comprised of memory elements and
combinational logic.
Jim Thompson
On Sep 30, 7:00 am, Joerg <[email protected]>
wrote: [snip]
Indeed. My latest POR had hysteresis of 3.5VT/3VT plus a delay to
ensure it held "resetbar" down long enough.
POR was used only on the digital sections... analog functioned on a
"bandgap ready" signal.
...Jim Thompson
Joerg
circuit.
[/QUOTE]
[/QUOTE]
The customer won't even be able to hold a DVM to it if on-chip. What
customers like me really want to see is a POR plus BOR where brown-outs
are handled properly. Anything less than that is a risk. For some reason
it usually takes the uC folks years to figure that out, no idea what
they find so difficult about it.
Joerg
circuit.
[/QUOTE]
[/QUOTE]
There were elaborate uC solutions I found in my career that I have
replaced with 20-30 cents worth of logic chips and some diodes. This
"TV-dinner" behavior already started with the advent of PALs. Almost
everyone was jumping on them (except me ...) and they were wasting lots
of power. And money.
M
Michael A. Terrell
Joerg said:
Big tubes, CRTs and the like you can get from Western mfgs. But any
regular tubes will be NOS.
Some of the HV stuff is still being made in small runs.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
John Larkin
Cute trick: use an HV rectifier, like a 1B3, and control its filament
voltage to make it an amplifier. I used to do that when I was a kid...
flashlight battery, rheostat to filament (with long plastic shaft!),
neon sign transformer, charging a bank of oil caps, with the loop
closed manually. You could run the xenon flashtubes just below the
point where they'd fire spontaneously.
Amazing I'm still alive.
John
M
Michael A. Terrell
One TV tech I worked with when I was 13 would reach into those old
tube type color TV sets and grab the second anode lead, then touch
someone. ONCE. Most people never got close to him again, after that.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
K
krw
Poughkeepsie? That's where my father had to go, looong flights back in
them days. He worked at IBM in Germany.
I worked in P'ok for 19 years. Great place to be *from*.
It would definitely be too cold up there for my wife. Her ideal place
would be where winter simply doesn't happen. Like Hawaii, but there is
no work for me and getting to clients would take forever.
From there, we moved North 200 miles but looking to get out for
somewhat warmer climes now (the instant the house sells). The
Winters do suck and it looks like we'll be there one more. :-(
